How to Safely Add Volume to a Training Plan
When you have extra time to train, you can enhance your training plan with additional workouts and maintenance activities. Adding extra volume can be beneficial when added appropriately.
For more information on training check out Ask a Cycling Coach Ep 253.
Adding Volume: Stick to Low Intensity
When adding volume to a structured training plan, you’ll want to avoid adding additional high intensity. Your structured training plan integrates appropriate amounts of intensity, and adding too much intensity into your plan can be disruptive and counterproductive.
If you can take on more intensity productively, you should increase your whole plan volume. If you increase your plan volume, any additional intensity will be progressive, periodized and, aligned with your training goals. That’s not to say you can’t add volume to your plan without increasing the volume of the entire plan. If you know you can’t productively maintain the additional intensity that comes with a higher volume, it’s best to add low-intensity, endurance-based workouts to your regular training plan. Adding extra endurance is easy to do, and there are numerous ways to do it.
Add Workouts With TrainNow
If you want to add workouts to your structured training plan, we recommend using TrainNow. Powered by Adaptive Training, TrainNow uses your performance in completed TrainerRoad workouts to intelligently recommend structured workouts. If you want to add structured volume to your week, TrainNow is the best way to find workouts compatible with your schedule and current abilities.
When you open TrainNow, it gives you three different options. An attacking workout, a climbing workout, and an endurance workout. If you’re following a TrainerRoad mid-volume or high-volume training plan, we recommend sticking to the endurance recommendations. However, if you’re following a low-volume plan, you might be able to add the occasional climbing or attacking workout at your own discretion. Don’t see the workout you want? You can adjust the duration of the workout in the upper right corner or refresh your training options.
Do Two Workouts in a Day
Another great way to tack on volume is to do two workouts in one day. In addition to the scheduled workout you have on your Calendar, which will generally be a structured interval workout, try doing an endurance workout too. By adding an endurance workout to your day you’ve increased your training volume without adding too much training stress. Any workout under an hour, in this zone, is an easy addition. You can use TrainNow to find additional endurance workouts fit specifically for you and your current fitness.
The Benefits of Two in One Day
Adding a second workout to your day can benefit your muscular recruitment patterns. When you do your first workout of the day, it can fatigue the muscle fibers you regularly rely on. During your second workout, your body may not be able to utilize those muscle fibers like it regularly would. This forces your body to use different muscle recruitment patterns. When your body utilizes different muscular recruitment patterns, it has an opportunity to discover more efficient recruitment patterns and strengthen muscle fibers it may otherwise not use regularly. This is why we recommend doing the lower intensity endurance workout first, followed by your hard workout or interval workout later on.
Extend Your Cooldown or Warm-up
If you don’t want to add additional workouts to your week an easy way to add endurance-based volume is to extend the cooldown or warm-up of your workout. Adding a few extra low-intensity minutes adds up when you do it every ride. It’s also easy to implement. You don’t have to organize an additional ride or even get off the bike. You can keep on pedaling and add time as you see fit.
You can also choose how much time you want to add to your cooldown or your warm-up. In the TrainerRoad app, you can add extra time in one, five, and ten-minute increments. Whether it’s an additional half-hour, twenty minutes, five, or anywhere in between – the choice is up to you.
In addition to this you can opt to do certain “plus” versions of a scheduled workout. While some “plus” versions add more intervals, others add endurance to the end of a regularly structured workout. If you know you want to add endurance work to your ride, go to the TrainerRoad workout library and look at the other versions of your scheduled workout to see if any align with your goals for the day.
Think Outside the Box
Additional time on the bike isn’t the only way to add volume to your training plan. Attending to other aspects of training and recovery can be as beneficial as spending more time on the bike.
Maintenance, strength work, foam rolling, stretching, and fundamental skill work are all excellent places to dedicate extra time. A lot of them don’t demand a lot of additional training stress but create an opportunity for tons of improvement. In addition to obvious benefits, choosing to spend your time working on something else can be refreshing and help prevent burning out on your training.
Don’t Overdo It!
Additional training isn’t beneficial when it prevents you from completing structured workouts in your training plan. If the extra workouts fatigue you to the point where you’re unable to complete regularly scheduled training sessions, then you should scale back. Instead, try using that extra time for a low impact maintenance activity or extra recovery.
It can be easy to get carried away with training when we have extra time. Remember that maintaining a healthy, balanced training schedule, that’s proportionate to other priorities in your life, is important too. Add workouts and activities that enhance your training without interfering with it.
