105% rule still valid?
You quoted Hambini’s faked aero wheel test?
Seems like 105 is merely a starting point that has been made much more complicated with the increasing growth of tire widths. I myself was at one point only concerned with internal width but have learned that for low drag and stability in crosswinds that the relationship of internal and external width is critical with ratios lower than 75% being the most beneficial. Had no idea how much this mattered until I read through this.
While I realize this is just one article, it is quite methodical in its approach and does seem to make sense.
I’ve only skimmed it but where is this 75% rule explained?
It doesn’t really make sense to me logically, and I fear it’s one of those things chucked out there on YouTube that develops a life of its own and becomes fact.
There is a table they show with the ratio of inner to outer width. Wheels that had a ratio 75% or lower tested much better in crosswind stability. It generally works well from what I can tell if the delta is about 10mm. That gets in the ballpark.
There is such a large amount of data on this subject. My first wider carbon wheelset was a 2001 vintage set of Zipp 404 Firecrest that were purported to be more stable in crosswinds, they were not.
I must be going mad. I can’t see that table in the document.
Where is the research of inner to outer ratio correlated to cross wind stability?
I think I may have misquoted the report and I found the table in another report that also spoke about rim width and relationship to inner width as well as tire width. My appologies for misleading anyone. What I was hoping to convey is that there is much more going on than simply the 105% rule as there are several other factors in play. A close friend bought a pair of CRW’s earlier this year. Those wheels.are supposed to be very up to date, yada, yada but he has found them to be somewhat sensitive in crosswinds and the same has been reported by others,
Sorry again for referring to one article when I actually saw the chart in a video. Here issue video.
What width tires would you recommend on those Reserve 52/63? Asking for a friend :thinking:
That’s where I thought it came from.
Jessie completely (and openly) made up that ratio. It it not based on research.
A much easier way to resolve crosswind instability is to stick a conti aero 111 on the front.
This :point_up: re: the “rule of 75” lol.
