2023 XC Bike & Equipment Thread
Also if depends if you run a Lockout and use it. I like v supple but I use a 3 pos for the rear only (front stays open all race). If you ran no lockout you might need to depend on a digressive shock / asq
Pending 2024 model info:
I don’t follow mtb tech as closely. Is this supposed to replace the 35mm stanchion Ultimate or?
Sounds like it’s mostly a normal update. SID is still 35mm and slightly lighter. SID SL is still 32mm and also slightly lighter. They both also have longer stanchions (or lowers?) and are now offered with a 3-pos lockout.
Another one:
Interesting. Looks like a nice fork.
I actually thought they were working on a 120mm SID SL, I’m glad it’s the regular SID for stiffness. I hope they have sorted the bushing issues with the increased overlap.
Having recently picked up a bike with a Lyrik and having had a SID on my old Anthem, I really rate the RS stuff. I was too scared of having a faulty fork to try the SID this time around though on the new build.
The new SID blue on the BikeRumour/Flow review is a heck of a nice colour! Surprised they’d move away from that identifyable sky blue though? I also feel vindicated by Kaz suggesting the wireless remote, I can’t believe they haven’t done it, but I imagine they don’t want to cannabilise the potential FA market.
I’m pretty excited about these. Overall I’m very happy with my SID Ultimate but the bushing issue is a bit annoying (I’ve warrantied one and there’s minor play developed in my current one) and I’d really like to have 3 position remote lockout to match the Fox DPS I have in the rear. I’m a big fan of the climb mode I used to have on the Spark.
I don’t see these available anywhere yet - any one have a line on availability?
I’m in generally agreement with you (more bump absorption = more speed), but I’m curious if you have any way of quantifying the effects or figuring out what’s ā€˜optimal’. At some point you have too little anti-squat and are suffering from pedal bob, or supple becomes unsupportive, etc. I ask because you seem to have put a lot of thought into your set up and are using it a high level.
A 350W FTP also helps smooth the trail out :sweat_smile:.
For what it’s worth, I’m going to try the 34 on my bike first. I had a 34 on my Spark (very active suspension) and it was manageable but the trail mode was used a lot.
Now with no lockout at all I’m tempted to go 32 for the reasons discussed above. I am worried about spending too much time in the bottom end of the cassette though.
I have a mate who’s strong like Nueromancer and I was trying to convince him to try a 34 but he hated it. Much prefers the 32 even though he’s got Watts for days.
I wish Sram would stop listing blatantly inaccurate weights. I got the weight values from a couple of the reviews vs most of the review info just lists the Sram claimed weight. Looks like the SID SL Ultimate not on the Sram site yet.
Figuring out real weight wouldn’t matter much since can just call it similar to old, but now there’s 2 options for 110mm travel added.
Length Weight Size Name
120 1600g weighed vs 1480 claimed on sram site 35 SID Ultimate
110 1510 weighed vs 1352 claimed on sram site 35 SID Ultimate
110 1369 weighed R2 bike 32 SID SL Ultimate
100 1326 claimed 32 SID SL Ultimate
Is your 34 a SC or the regular? I have a 2020 performance 34 on my Blur TR and am really wondering if its worth upgrading. I am really threading the line between DC and XC with this bike. My buddy says the SC felt like a noodle underneath him and is adamant its not enough for the racing or riding around here. He’s a big guy at 200 lbs, but I am not far off at 180. I would love to try a Sid or 34 SC and see how it feels!
My Spark had a 34 Performance Elite. The new build is a 34SC Factory.
I haven’t been out on it yet, you can immediately feel a significant amount more ā€œsupportā€ from the SC though with its smaller negative air/tune.
The reviews I read (and it was a lot) all said the 34SC was impressively stiff, not giving much up at all to the regular 34. It looks noticeably narrower, but I can’t imagine it being much flexier, and the tubes look as substantial as ever. Your mate is a big dude though so might be able to flex more out of it. I wonder if it’s front wheel flex also?
The German shop r2-bike publishes confirmed weights for everything they sell.
For example the new Sid Ultimate:
Which cog do you all prefer to have the chainring in line with? Assuming 12-speed 10 to 50something, and standard Boost
Really just not sure what people are worrying about with the 34. It’s a 120mm fork. You set it to 15% sag or something. It tracks the ground. It doesn’t bob under my 75kgish weight. It doesn’t feel Uber plush, but it controls the front end through technical terrain. It’s an xc race bike - you can get more support by adding more air :slight_smile: .
Tracking the ground and not bobbing is pretty straightforward to dial in with most forks (imo). The challenge is how the fork performs at the limits, with limited traction and under hard breaking, especially in technical terrain. Its one of those things where the difference are at the margins, but they are pretty big differences when you hit them.
Its also a function of the terrain you race in as well. I find in really rough, technical descents you can absolutely bleed time if your setup isn’t dialed. I did an XC race in Whistler in June, in a stacked field the winner was on a Fox 34 140mm with Forekasters, which is kind of a crazy aggressive setup.
I think its one of the coolest things about modern XC, is that the courses are getting so diverse that the perfect setup can vary sssoooo much from race to race.
Interesting thanks.
R2 lists the same weight for 100 and 110mm SID SL Ultimate. It sounds like the default is 110 and that changes to 100 with a change in the air spring length. Different spring seems like it would be different weight but maybe essentially the same.
Might be as simple as shifting a spacer.
Those of you running AXS, what’s your preferred shifter type, and location (pictures if you’re able) please.
I have GX AXS and have put Leap Quickshift on but the shifter position still feels awkward. It might be something I quickly adapt to on the trail, I have been moving it around and trying to get a feel for it in the garage while waiting on bits.
I have Blipshift as well to try but seems like I should save those for race day or summertime use (just for maximising battery life).
I’m wondering if the Pod style is better…
Alright y’all, asking a favor…
I’m hoping my math is right… I’m trying the find the point on my MicroSpline hub where the chain is 52mm from the centerline.
The question marks (end cap to start of freehub) are 13.7mm measured with calipers…
So 22 - 13.7 = 8.3.
That is, 52mm from the middle of the hub is 8.3mm inboard of the freehub outer edge.
Does that look right?
In case you want to know the backstory, I’m considering a single speed conversion for my Procaliber and I want to know what width spacers to order to get the cog lined up with the Crankset.
