After breaking another fox lockout lever (think this is number 5) I can’t wait for my next bike to have a simple switch on the shock & fork. Remote lockouts are unnecessary with a modern bike that pedals well, but it is nice to lock it out for road connections.
The F Podium is basically a kilo heavier than any of the other bikes with equivalent wheelset / finishing kit.
The DC and RR is no different in weight as it is the same frameset just with a different stroke shock (same eye to eye).
That’s out of the window.
An element is a different proposition entirely - it would be a trail bike that is just about light enough to whack a set of race kings (maybe 25mm internal 180 hubbed light wheels vs heavier 240 30mm wheels with your trail tyres on) and race.
There is a very pretty one for sale near me…(if he’s on here I apologise but I am considering messaging you :D.
Weird question for y’all… any aftermarket chainrings that would convert my XT Crankset from a 52mm chainline to 55mm?
I want to run a 38 or 40t chainring for gravel, but I’m limited to 36t per frame specs. Any extra up front to avoid spinning out and minimize the 10-12-14 jumps on the cassette.
Edit: now that I think about it… quite possibly the most cost effective method is just a 55mm Deore crankset. That way I wouldn’t even have to mess with the DM chainring tool.
Wolf tooth just announced their 0mm offset chainrings to allow for a 55mm chain line with old cranksets to match up with transmission. I don’t know that they have the Shimano versions out just yet, but they are coming.
Having had 2 Mondrakers, a 2014 Foxy and currently a 2017 Dune I can fully confirm that their “Zero” suss design is amazing. Even on the Dune (160mm F/R) with no lockout, there is very little pedal bob etc.
Rich Payne has built up a new Mondraker which is a good looking bike as well. Frustratingly I haven’t heard him say why he swapped frames or compare it to the Orbea. Presumably it’s just a product placement and not a frame he bought himself .
I have seen them popping up more on my IG feed and they’re a fast looking bike.
From what I understand, it basically makes no real difference. 52mm cranks work just fine with Transmission, and why wouldn’t they? The rear spacing hasn’t been changed.
So I found a 40t “-3mm offset” chainring that fits Shimano direct mount. Doing some measuring, that -3mm means 3mm outboard of the OEM chainring. That puts me at a 55mm chainline.
Installed, I’ve got close to 4mm between the chainring and the frame (WT on their own website recommends 3mm minimum). So I figure I’ll throw on some helicopter tape and call it good.
Just for kicks, I mounted the chainring backwards, ending up with a 53mm chainline and approximately 2.5mm clearance. A little too close for comfort for not a significant change in chain angle, but an option I suppose.
I just went out and looked at both of my Shimano 12 speed bikes. There’s no room to move the cassette outboard by 3mm and not have the chain actually hit the frames, or at least be right there.
Maybe bikes built around UDH and a 55mm chain line are different, and none of my bikes are.
