I use Oakley wind jacket 2.0 it’s quite a rare frame that was originally aimed for ski touring. They do what they say in the name 100%
Thanks again for your recommendations! I tested some of the glasses (couldn’t get a pair of Oakley Wind Jackets):
- 100% Speedcraft: Shares the last spot with Bliz Breeze for worst wind protection.
- 100% Speedtrap: Best close/wraparound fit out of all the glasses however they were not the best in terms of wind protection.
- Bollé Shifter: Very big and heavy frame, sits higher up than other glasses. For me they’re in the middle category, so not particularly good for wind protection but not the worst either.
- Julbo Rush: More heavy than most glasses I compared them to, fit is close to the POC Crave. Wind-performance seemed a tiny bit better than my Jawbreakers and about on-par with the POC Crave.
I’ve also found (and ordered) the Rudy Project Agent Q, which is a mixture of cycling and motorcycling glasses with the option of a foam seal around the eyes. Will post my findings with that pair when it arrives.
Try safety glasses… like trademen use or you get at the hardware store. You can get some Transitions Active ones, which are great, but try a $10 pair first.
Have you tried something to keep your test ducts open? There are a few brands and active ingredients that work, the thickness of the eye drop seems to matter. The Alaway, Bauch, and Orange z-something brand work well.
Have you tried adjusting the nose piece of the shifter I can bring it quite close to the face by flattening the nose.
Yep, my main issue with it was the sides, the glasses were close to my forehead but didn’t wrap around as tight and left a big gap at the sides and the bottom (which seems like the problem I had with them).
Since I had issues with even the Speedtrap (for me it fit within 1-5 mm all around my face), I guess it’s an issue between my high prescription on the contact lens and any amount of wind. So maybe I’ll find a frame that tolerates a ton of prescription (most don’t) or hopefully something like the motorcycling or security style glasses work.
It’s not an issue I’ve personally struggled with as someone who primarily rides MTB and doesn’t wear contacts or glasses. That said, based on where it seems like the issue is for you (wind coming around the sides), have you considered a more mountaineering-oriented option? Something like the Julbo Shield may be a nice compromise that offers some added shielding without going the full-on traditional mountaineering glasses look, which admittedly would look odd for cycling.
I’m using Maui Jim Wassup wrap glasses with prescription lenses. Bought them before I took up cycling and they work really well.
I’m somewhat sensitive to wind, not overly sensitive.
Exactly to the point, they were up next and already in my amazon cart! The Rudy Project Agent Q is in a similar style plus it has a foam seal all around. The blinders actually do a lot, however they still let in a mild breeze around the edges - though not as bad as any of the other glasses I tested.
I also gave the Speedtraps another go and taped the vents in the lens shut. The difference is immense, taking them to on-par or maybe even slightly better than the Agent Q.
So both the more mountaineering-style Agent Q’s with their foam seal around the eyes (even if it doesn’t seal the outer sides) and the Speedtraps without the vents works well for me (what an experience it is to suddenly have clear vision at 60 kph in winter!).
So as a conclusion (at least for my issue with the strong prescription contacts on only one working eye) a tight seal to the skin all around the glasses seems to be essential for good wind protection. At least that would explain why I didn’t like the POC Devour at all and love the 100% Speedtrap and the Agent Q.
Thanks everybody for your contributions and input!
Hi!
I have the same problem as you, I’ve even had my contact lens pop-off at 50kph… really scary stuff.
I was wondering how you find the Oakley wind jacket 2.0 vs 100% Speedtrap glasses, as I think these might be the best options for me.
thanks!
I totally understand your struggle—cycling with sensitive eyes, especially when wearing contacts, can be such a challenge. It sounds like you’ve already tested quite a few popular options. Oakley Jawbreakers and POC are solid choices, but if they’re still not cutting it for higher speeds or colder temps, it might be worth exploring options with better wind protection.
Have you looked into wiley x prescription safety glasses? They’re designed for extreme conditions and offer excellent coverage around the eyes. Their snug fit helps block wind effectively, and they have prescription options if needed.
Another tip—some cyclists use glasses with foam gaskets or similar inserts to seal off airflow even better. While not as sleek as standard cycling glasses, they might be worth considering for those tricky descents. Hope this helps, and good luck finding the perfect pair!
