AT: Easy vs Moderate vs Hard vs ... [Pass / Success Survey Responses]
Hence the reason I made a bit of a joke,
  • image
and another one,
  • image
:joy::rofl::+1:
Looking for some clarification from the team on if/how we’d like to best provide an update here, stay tuned!
There are clearly problems here.
AT is a system that says “If this [workout + survey response}, then that [particular kind of adaptation.” But if we game the system to get the result that we want [eg, we mark a 2-hour threshold workout as “easy”] because we want a faster progression, then we are doing what AT was meant to be doing. What will AT’s response to this kind of behaviour be? Can it react sensibly?
What we don’t know is whether AT’s adaptations are “linear”. For example, if we mark an Achievable workout as very hard, then we are likely to see a reduction in out Progression Level for that energy system. We’ve heard examples of this. But if we mark a Stretch workout as hard/very hard, would we see a similar reduction in PLs? Our examples do not indicate an example to this question.
FWIW, I follow @mcneese.chad’s scale. Comparing the workout to my expectation is contrary to the question asked [thanks, @AldridgePrior for this clarification] and could only really be meaningful if the question was posed as: “This workout was meant to be easy [or moderate or hard] for you; was it easier/harder than or the same as that?”
Yeah this is key. Assuming the recent responses from TR Support are accurate, and Moderate actually means as expected, it sounds like this is the question AT thinks it’s asking. If we all answer the question that’s actually displayed, AT’s not going to function properly for us even though we’re Technically Correct™.
Also I love your wording. I can SEE IT NOW
You took the words out of my mouth, this is exactly how I feel about this. And why I’ve been frustrated with the lack of and/or the proposed adaptations based on my survey responses. I have yet to give anything besides Z2 and recovery rides a Moderate, and have not given anything an Easy. Most of my rides have been Hard or Very Hard, because that’s how they felt to me. It would never even cross my mind that I should rate a VO2 max workout as Moderate. So now I’m getting downgraded adaptations and I think I’m going crazy because I’m hitting my workouts but still getting adaptations to decrease the workout levels.
So I either trust AT and pick a lower workout (sometimes by a full point or more), which would still probably get a Hard or Very Hard rating if it’s VO2, and I create a spiral of never getting harder adaptations because I never rate Moderate. Or I continue to decline adaptations and progress based on workout levels, and keep rating Hard or Very Hard. But then I’m in the situation where I never accept adaptations, and AT isn’t doing anything for me and I’m just picking my own workouts.
Either way it’s frustrating. And it seems that there hasn’t been a specific answer.
Ivy’s working on it :slight_smile:
According to this blog post (How to Use Adaptive Training - TrainerRoad Blog), it should be RPE based and not how it was expected to go.
“You will see different surveys based on how your effort in that particular workout went. The most common survey you will see is the one pictured above, which asks you to rate how the effort felt on a scale from one to five. When answering the survey, consider the entire workout, and don’t worry about how you expected it to feel based on workout type.”
It literally says to base the survey on how it felt, NOT how we expected it to feel. To me, the TR support answer is the complete opposite of this blog post.
Actually in the situation that I posted the Customer Service response, the situation was close to the second. I had performed a stretch workout successfully, but rated it as very hard. it slightly downgraded my adaptations for the following weeks.
When I take a step back from being frustrated about my training potentially being less effective than I had anticipated based on the TR promotion of all the wonder of AT, and realize that beta is still fraught with issues, then this discussion should do exactly what a software company would want to get out of beta. IMHO that would be that a gap/issue has been clearly identified so the company can determine what should happen, resolve the issues, and deploy a solution.
So let’s see how TR does acknowledging the issue and getting clearer direction to those of us in the beta so we can both a) experience the benefits being touted and b) find different things that TR could/should address in their continued progress toward general release.
Great picture! Exactly.
I know this suggestion is essentially “wrong” and not what TR wants, but I feel the underlying effect of what I wrote is what it seems they are actually doing with our survey responses. Look at the middle column with blue text, as my guess to the actual results when we pick between the current options.
I am sure this is not entirely accurate, but it seems more aligned with what we are learning from TR support. Despite the apparent aim to make this survey individual and adaptive, it looks like they are just applying simple rules that set a defined outcome from each selection. And IMO, the apparent outcome doesn’t match with the broader interpretation of the loose & vague terms TR applied in the “feeling” survey.
I get what they were trying to do, but I think there is a very big miss with the current implementation.
Yeah, I never would have guessed that I was supposed to be comparing to how the workout was “supposed” to be, which is also kind of a hard thing to know. My own RPE is much more straightforward and easier to judge.
This has been a big reason I have actually recently stopped using AT. I’ve been so frustrated with trying to figure it out that I feel my actual training has suffered. Going back to just using the set plans I feel a lot better so far. Maybe when they fix all the problems for the main release I’ll come back.
Even if I rely on my own RPE, that’s a very imprecise measure. Consider a 2 min VO2Max, 2 min recover repeated 10 times. 2 min at VO2Max certainly qualifies as a hard effort, but with plenty of recovery and only 10 repetitions, I’m still feeling pretty fresh after the workout. So should the workout be easy/moderate because it was easy to finish and I feel fine afterwards, or should it be hard because the 20 min of VO2Max were right at the edge of what I could do for 2 min at a time?
How about a ramp test? By definition, I’m going til I can’t go any more, but 5 minutes after I finish the ramp, I’m feeling fresh and can take an easy/moderate ride with no difficulty. How do I rate that workout?
  • That workout / Test / Fitness Assessment is an exception, where there is no completion survey offered of any kind AFAIK. (I’m guessing the 1x20m and 2x8m tests would be similar, without a survey?)
  • I presume that by definition, it is a maximal effort which precludes the need for a survey. If you fall short for any reason, you can retest or manually adjust FTP.
I would revise how you do the vo2 max in this case :slight_smile:
Update! We’ve added more information on surveys to the ‘How to Use Adaptive Training’ article, I’ll post it here as well!
How to Rate Your Effort
  1. Easy
    This workout felt easy and required little effort or focus and felt non-taxing.
    (For context, this should feel like a little bit more than a recovery ride, ie you could do this again now and could pass it with no problem.)
  2. Moderate
    This workout was somewhat comfortable but required some focus to complete.
    (This was a normal feeling workout where you’ll feel challenged a bit, but not as though you wouldn’t be able to finish it. I could do another set of intervals or extend the ride.)
  3. Hard
    This workout required effort and focus and was challenging to complete.
    (This will feel tough and you’ll probably look forward to this workout ending, but if there was another interval, I could have done it.)
  4. Very Hard
    This workout was very difficult to complete.
    (ie if there would have been one more interval, you wouldn’t have been able to do it.)
  5. All Out
    This workout was extremely difficult. It pushed me well beyond my abilities and took a massive amount of energy and focus to complete.
    (You’ll feel like you barely made it to the end of this workout, and that you had to pull out every trick in the book mentally to finish it.)
Its important to separate your expectation of what the workout will feel like (either from the Workout Level or from your Progression Levels) from what you actually experienced through doing the workout. Try to speak exclusively to how the workout felt, regardless of that context of expectation.
Let us know if you have more questions!
Thanks Ivy, just one thing - those bits in parentheses are quite helpful, but they’re not present in the page you linked to. It would be worth including them :slight_smile:
These seem to align well with my prior comments. I may have to consider the relationship between Moderate and Hard, in light of the supplemental comments on the possibility of more intervals or ride extension. But this still makes sense on a broad level to me.
I thinned the text down a bit for quick reference, as well as standardizing the “I vs You” approach too.
I also “struck out” the prior comments in my doc that were shared by TR support on an individual level, and consider that all to be null and void at this time.
