youâre completely right! sorry and thank you very much!
my apologies TR team!
Second workout - two drops/freezes using BT closer, at the first recovery switched over to ant+ in same location and worked perfectly for the rest of the workout
Awesome TR Team!
https://www.trainerroad.com/career/getbrem/rides/56768426-palisade
1st workout report
OVERALL: LOVE THE UPDATE so so good
bugs i noticed on mac running High Sierra 10.13.6 - i did McAdie +1
no countdown blips to intervals ⌠beginning or end
no interval summary
otherwise awesome and hugely appreciated!
Template Info
Version: 2019.16.0.32-Beta
Devices: Kickr Gen 1, Quarq Riken
Connection: ANT+
Mode: ERG
On my ride yesterday - Log In to TrainerRoad - the pop interval pop-up never popped up. This ride was created yesterday using the Workout Creator on my Mac, starting from a blank âcreate custom rideâ.
Iâve seen this same behavior - the post interval pop-up not reliably popping up in both the âproductionâ app and the previous beta app for custom rides.
Was doing Xalibu+4 this morning, some weird things going on with power match. Canât tell if itâs Beta related or not. Massive power overshoots and then not stabalizing quick enough causing issues. I tried different gearing 34x18 and 52x18, and different issues with both.
You can see in the first interval the 1st sprint overshoots by a lot and then doesnât drop which causes the whole set to be harder than needed. Did it the same on set two which just made it too hard. Set 3 I changed gearing to the 52 and then it was undershooting the power target on the short 15s intervals.
With workouts like this when it is missing by this much it just makes them incredibly difficult to complete as specified.
https://www.trainerroad.com/career/rondal/rides/56805859-xalibu-4
Weâve had a few users point this one out - we have an existing issue created for it Thank you for your diligence!
Hey @swin2000,
Would you be able to post a screenshot as a reply to this thread of what youâre seeing on your end?
There is a specified minimum size of the app window where it wonât let you reduce any further, but you shouldnât be seeing any major content within the app being cropped off due to it not being in full-screen mode.
Thank you for your feedback!
No apologies needed - we appreciate your feedback!
Hi guys,
I know this has been a problem for people in the pastâŚbut the battery on my Stages PM drained by 25% in the one workout (Started at 75% and at the finished at 50%). I follow the protocol of completely shutting down the app on my Mac immediately after too. Happy to provide more info if needed.
MorganB
update:
countdown bleeps are present in FULL screen mode but not minimal âŚ
Weâve got an issue in for this one! Thanks for the report.
This oneâs a bit odd, because we just take the message that the PM sends us and display that (weâre not actually calculating how much juice you have left). I think it might be different from device to device, but I believe the Stages might not show actual percentage. It will show the % in quarterly buckets, so 100>75>50>25. It might be rounding your actual percentage, and when it hits a certain threshold it will just show the next lower bucket (e.g. you went from 63% to 62% so it showed a drop from 75% to 50%).
This is speculation, and Iâm not 100% sure thatâs accurate. But we can discuss what we want to do (or even can do) to make the battery percentage more accurate. Thanks for the report.
Just to expand on this, I think the minimum resolution of our app is 1024x768. If you have the scaling set to larger text, the app may get cut off. Weâve seen this and weâre looking into any potential resolutions. At a certain point, Iâm not sure we can scale our app to a lower resolution - thereâs an open issue for our devs and design team to have a discussion on this.
This for me too.
Windows 10, when running minimised on a 20 inch monitor. My eyes are pretty decent, but itâs very difficult to read, especially when squinting through the sweat!
Oh come on, be honest!
âsweatâ aka
For your first point I saw you mentioned that this was for minimal mode only, for which a fix is currently in for that!
For your second point, could you elaborate a bit on what you mean by âno interval summaryâ? Is this also in minimal mode?
yup that . is correct
during the âhurtâ of the interval i didnât notice that it was displayed in far right corner ⌠so it does work! - my bad - however, might be better/easier if it appeared on top of workout bar like it used to in minimal mode.
either way - love it !
In the Devices section, the manual calibration button of the power2max doesnât seem to work, as it doesnât return an offset value like the previous beta did. It remains on âCalibratingâŚâ.
Ahh, gotcha! Thanks for the feedback and Iâll pass your suggestion along to the design team.
Glad to hear it!
Hi there! For calibration of power meters, once the calibration has successfully completed it will change from the âCalibratingâ state and say âCalibratedâ along with an offset value.
This is standard knowledge of course, but make sure your pedals are in the 6 oâclock and 12 oâclock position when calibrating. If you wouldnât mind trying again when you get a chance and see if it goes through that would be helpful!
If you find that youâre always stuck in âCalibratingâ and never get it to successfully calibrate, let us know and we can look into it some more.
