Cervelo aerobottle 500- any experience?
Thanks for you reply
Also have a 58cm frame, so it should fit.
“I would say, however, that we could have probably dilled other holes to effectively “push the bottle cages higher on the frame.” Have you tried this?”
→ yes, tried this as well,
drilled some holes to put the cage higher, but maybe I have to push it some mm further up…
Cheers!
If the bottle is filled, I do not have any problems to put the bottle back in the cage. If it’s empty, it’s a bit more hustle
Interesting I just read your post. I need something for the seat tube of my Shiv Tri Disc so will look into it.
