Chain Waxing Tutorial
I think DaveWh was comparing 1 immersion waxing (IE Gulf Wax, MSW) 2 drip wax (IE Squirt, Secret Lube) 3 drip oil (IE Rock and Roll Gold) and he was rating which is the best for different criteria
I didn’t particularity like Squirt
I don’t generally ride in the wet or mud - immersion waxing is my 100% go to - I don’t see ever going back. However if you ride in an environment that is frequently wet/muddy/sandy I can totally see where wax isn’t the end all be all for everyone.
I used hot melt waxing. Not worth the extra effort vs drip wax IME.
Completely this. I have 4 chains I rotate. I just like to do them in batches. I don’t keep track of mileage. I just put on a new chain at the end of the week.
The only thing I don’t like about waxing is cleaning up all the wax flakes by my trainer constantly.
Regarding don’t overthink it…
My wife had a bunch of basic paraffin unscented taper candles from TJ Maxx that sat on a shelf for like 15 years and never got used.
I’ve been waxing for at least 3 years on that stash, 15000+ miles and haven’t even thought about replacing a chain or cassette. Can’t even measure any stretch wear among my 3 chains I rotate.
I did the initial clean thoroughly - but I don’t bother for rewax. Just drop it in, swirl a few times, give it a couple mins and pull it out. After maybe 15-20 chain dips, if it’s not as white when dry, chuck the wax and get another candle. A little grit and sand will settle to the bottom of the pot that I wipe out.
I’m finally running out of candles and may actually have to buy some wax…
On the podcast, they really missed this #1 reason to wax. Your drivetrain becomes immortal. The studies looking at this are incredible. And that is worth huge time and $$$ in a scarce market. Clean to touch quiet chains and free watts are a nice bonus!
what do you bathe your parts in? i assume for wax, you’d just use hot water. similarly to just boiling on the stove.
I saw this unfortunate news over at the WW forum. Steven John Leffanue (Oz Cycle YT Channel) has posted several videos about waxing on YT I’m sure many of us have watched or used as a basis to get into waxing.
WHAT
Oz Cycle did this??
I am shocked beyond belief
Yeah. I was really unsure if this should even be posted here since it really doesn’t have anything to do with waxing.
Mods can delete the post at their discretion.
Had to go check to see who was who… fortunately, I’m in the ZFC camp. :slight_smile:
I watched some of his videos when I was just getting into waxing but really got most of my info from MSW. Haven’t watched anything of his in years though.
Same, ZFC has always had real data like Friction Facts before him. OZC on the other hand… not so much.
I got a connex link (steel) for my 10 spd shimano drivetrain, for endless capacity to take the chain off for cleaning. On the 11t sprocket it skips. Mine came with a very large outter plate, I don’t know if that is normal, but I am guessing that was the cause of the problem. I put sram link that came with the chain and no problems.
Sounds like you have it upside down. The Connex link is uni directional. The curve needs to mini the shape of the cassette.
See manual download link on this page.
Direct link.
Thank you!
I am embarrassed to say, that is very likely what happened. Will give it a try next time I switch chains, which is very soon.
Edit: but then on mine the “10” engraving is upside down! No wonder I got it wrong …
Still, I too would very much like a 12spd version for the mtb.
I waxed a brand new 12s XTR chain last night but after putting it on the bike, including engaging the quick link, I’ve determined I need to remove a link. Therefore, I’m wondering if the new Shimano quick link that came with the chain can be reused after being engaged but not ridden?
I reuse them several times on my SLX 12 spd. chains. Haven’t had a problem yet. When new, they are pretty tight to close and open but as you reuse them they loosen up. I kind of use my best judgement when they feel too loose I pitch them. I’m not endorsing this since it is not recommended, just what i (and a lot of others) do.
That’s funny, as that’s exactly what zfc suspects causes a problem with waxing kmc chains. He’s so against them I’ve gone to ybn and shimano. Here’s the ybn version in silver (gold also available for another tenner!). They’ll also prep and wax chains like zfc for a small fee
I have multiple quick links that I have reused over a dozen times each and never had an issue. If the quicklink locks in tight you should be fine. If it starts to feel “loose” or snaps in too easily I would replace. I think the main concern would be the link coming unhooked while riding.
Yep I have the Wolftooth compact chain link tool and extra links exactly for that reason. Well that and I did Unbound so I still have stuff in my pack that I’m never likely to need on a “normal” ride.
You did Unbound on a waxed chain? How did that go?
