Doing a "sweep" of all your levels
The productive workouts are only productive if your levels are high enough. That is why I suggested doing an initial sweep of every level instead of grinding away for weeks with workouts that are too easy for an experienced cyclist.
Oh I see.
This post and the whole (but short) thread has some useful info on how the PLs work, I found this interesting:
https://www.trainerroad.com/forum/t/increasing-ftp-v-working-up-through-the-pls/69488/3?u=dylan_van_green
To the other point
I think TrainerRoad is telling you they don’t agree. On this, I also thought this post and (again short) thread was a good read (there are probably lots of others):
You can manually adjust FTP but not the progression levels. Doing the sweep sounds like doing a series of very hard workouts as a means of ‘manually’ adjusting the PLs. Seems like you could achieve the same thing and get the PLs changed to your satisfaction by just manually lowering your FTP by 20/30w or so. It looks like from what was posted above that TR would then adjust the PLs up, so you would be served those level of workouts in the plans and get to use all the adaptive stuff going forward.
If you know what you want, you can ignore the progression levels and the workout levels, programme for yourself from the workout library. But if you think there’s any benefit to this adaptive stuff and you want to make use of it, you need to stay broadly within the TR ‘system’.
I wonder if workout levels change over time based on user input? For example was a level 5 threshold now a 4.5 because they have more data? @Nate_Pearson
Not yet. We might change ramp rates for levels or certain groups.
But there will be some tweaking coming up when we release a new system to score inside/outside workouts.
That doesnt work / have the desired effect.
The only way that seems to work is to sub in stretch or breakthrough workouts.
Having said that I think sweeping the levels is a bad idea.
Agree with others the level reduction after a ftp rise seems too aggressive for many.
I dont agree with the “just let AT do its thing…” I see people three weeks after a FTP change still at around Level 2 (starting around 1.2 and gaining +0.2 to 0.3 a week) when they are more than capable of level 5.
It might not be a good idea after a big bump, but if you’re an experienced cyclist just starting with AT, I think it’s fine.
I’ve done breakthroughs for three levels so far and they just long, not hard. Vo2max was more fun than hard.
