One comforting thing might be if you look at the public workouts of the same one youāve just failed, I guarantee that you wonāt be alone. These sessions are damned hard. Iāve failed a couple, learnt when to back-pedal and my fitness has gone up and up.
Thatās life, donāt sweat it and move on.
@jdv how do I check out other peoples rides? I didnāt know I could do that?
When I select āall ridesā, I just see all of my rides.
During my last rest week I failed doing Whorl. I was shocked. I gave it up after 50 minutes. I too was disappointed. Looking back, it was a rest week, it wasnāt a great loss. I think my head wasnāt in it, so I couldnāt push through. Maybe I needed more rest.
I just took it for what was and came back fine the next week.
Can you elaborate on the changes you made?
Thanks
I broke down my take on workout āfailureā in another thread a while ago ā link below:
As noted, if you dont fail any workouts, your FTP is too low.
It was tips that they discussed while talking with Amber.
Full disclosure: Iām a triathlete.
I typically train early in the morning. So I donāt have time to eat a big breakfast. So I would typically get up, eat about half a cup of Granola, drink water, have a BM, and then get on the bike. All in all, Iād usually be riding about 20-25 minutes after waking.
I would originally have a bottle with calories in it, but nothing too substantial. Iād take in maybe 200-300 calories for a 90 minute workout. Then it would be time for me to do a 5k or 10k brick run, and Iād do it and just be spent afterwards.
Like Nate said, I figured was tired and fatigued afterwards because Iād just done a hard workout. But then I made some changes for my next big workout after the podcast with Amber. The workout was a 2 Antelope + 5 with a 10k run tacked on to the back.
Still ate the granola. Just added a bit more.
As soon as I started turning the pedals for my workout, I ate a waffle.
I drank 2 bottle of Roctane at about 200 calories a piece.
I ate a gel after 30 minutes, and after 75 minutes.
The ride was challenging, and it worked my legs a LOT. But when it came time to do a 4.5 mile run at tempo afterwards, I felt like superman. My pace felt so much more sustainable, to the point, where I was running in my threshold range, and it felt the same as my old ātempoā pace.
I then did this for several more key workouts leading up to a race two weeks ago, and the increased performance was the same every time. I had never realized just how much Iād been underfueling.
The added benefit to this was that, like Jonathan also mentioned, I wasnāt as ravenous after tough workouts. I used to think that was normal tooā¦ that I needed to go gorge myself on a ton of food to recover properly. But when I consumed more while ON the bike, I could significantly reduce how much I consumed afterwards, perform better, and then recover better.
A few people have said that if youāre not failing (Iām assuming a couple of workouts) that your FTP is too low. I struggle with this. When people fail, I see lots of comments recommending a re-test as the FTP could be too high.
I honestly believe most failures start and finish in the mind. Some TR users seem to obsess over the workout before it has even started. I jump on the bike, hit āload workoutā and thatās it. I donāt know the numbers Iām aiming for and I canāt compare this ride to any previous workouts. Iām just there, in that moment and what will be will be.
This works for me because I havenāt allowed or encouraged self doubt. Control the mind and everything else will follow. Yeah, itāll hurt at times and boy Iāve hurt.
This is great timing, I had my first failed workout yesterday and I was feeling a bit down about not doing Dade +4 in full (normally I can just take a short break or extend a recovery and complete it, but not yesterday). But reading what people have said here lifted my spirit a lot.
I also might just have been stressed from real life as @Nate_Pearson has said multiple times, real life stress will affect performance, and Iām starting a new job on Monday so getting everything in order at my current job has me kinda stressed.
Even just Wednesday when I had an endurance ride planed I skipped it completely, I was planning to it after Iād put the kids to bed, but I was so tired I went to bed 30 min later (a good two hours before Iād planned). So something is affecting me, thatās for sure.
As @jdv and @BaronGreenback mentioned I just looked up how other people have fared with Dade +4, and that shit is apparently insane since most people actually donāt complete or tone it down a ton. That makes me feel a bit better as well
You didnāt fail the workout, you worked out for 50 minutes and gained fitness through it.
Failing the workout for me would mean staying in bed and not starting, or quitting before the first effort was through.
Weāre all human, just forget it, move on, and nail the next workout. No worries!
If you open the workout rather than your workout, so here:
You should be able to browse āall ridesā at the bottom and see how other users have got on.
I pretty much skip any session over an hour long as mentally I just cannot sit on the TT for longer than an hour I am literally dying inside from boredom, even Netflix only helps me for an hour max (I am doing a sweet-spot plan) so technically I fail once a week.
personally I tend to struggle with the long interval sessions like 85-95% FTP for 15 mins short break and repeat. sometimes on the last interval I have to slack off but I just move on and donāt think about it I know I am getting stronger as a result.
@jdv thanks a lot. I didnāt know about that. Looking at the other rides is definitely useful.
Thanks again for the responsesš
I would say that a failed workout every now and then means that your FTP is set just about right. Failing every 2 out of 3 workouts probably means youāre due for a re-test.
Training is like popping a bag of microwave popcorn. You want to get as many kernels popped as possible without burning the whole bag, so ya gotta keep bumping up against that line without going too far over.
failure is part of the game; maybe youāve uncovered a weakness of yours, which is a good thing to find; you can now work on improving those.
a gel or two before would be better than solid foods IMO, or just some carb based drink in your bottle. Iām not a big fasted fan but everyone is different.
move forward and best of luck!
Yup. All success or all failure is a sign of a problem. Could be FTP, or any of a number of influences as discussed in various other threads.
Struggling and/or coming up short on later intervals is a āhardā workout seems likely if you are properly assessed (FTP) and prepared (nutrition, mindset, etc.). This is subject to the intensity, duration and intent of the particular workout, but the āhardā ones should be hard in one way or another.
Skipping a few short on/off intervals in a billat style set is a good coping measure. Backpedaling in in recovery periods or even used to split longer intervals are aids that can allow you to get more time and power in zone, which seems to be the common goal of many workouts.
As such, employ these as needed, but also evaluate at the conclusion of the workout. Did I really āneedā them to get a full interval and/or set? Was it mental, physical, a blend? Did I hit the 95% (if that is right) goal compliance to the workout such that I consider it a āwinā?
Then push past a single workout review and see the trend for the week and even months. Is this a āone offā problem, or are these more frequent than they should be. That is where we have to take on some responsibility and review our own work. Then consider any adjustments that may be necessary to get up pointed in the right direction.
I think many here are hopeful that some of the guesswork above will be assisted by TR software. There have been numerous hints about ideas like that and more to help us get more directed and appropriate training. Hoping to see some releases soon per the teasers dropped by Jonathan at the very end of a recent podcast (198?).
I get so jazzed reading that the tips we discussed have helped so many people on here! Itās amazing how simple changes can make such a substantial difference. Iām very happy to hear this worked for you and that youāre enjoying the benefits of good fueling! Thank you for sharing!
Switch to Zwift, I hear they have fake training plans.
9 minutes at 105% is nothing to scoff at bro. Fuel up. Keep hitting it hard
