Did you print yourself the Di2 one? If so are you interested in selling one?
I have the same saddle with a stormproof seat pack that uses the Swat system on the back of the saddle. Do you think that both could fit together?
Hi. varia - Google Drive - here are files in 2 extensions, step is easy to modify if you need, stl is ready to print. I printed it with nylon and carbon filament and its solid. I used that plastic insert from original radar mount that came with it (marked on screenshot). Bigger bolt securing mount to seatpost is m4x12mm pin headed with locknut (nuts fit with the print is not perfect but it works, you can heat plastic a little to put it on its place) Bolts that are securing that plastic insert are m3x6mm also pin headed.
Hi Matte, i think it depends on the size off your pack and your saddle position. I sell it on etsy.
Many thanks for your prompt support.
Csaba
Thanks! Do you mind sharing the link to it, please?
Thanks
Shure!
Garmin Varia Adapter for Tarmac SL7 Seatpost with DI2 Port:
Garmin Varia Adapter for Tarmac SL7 Seatpost:
Garmin Varia Adapter for Venge Seatpost:
I’ve found https://www.racewaredirect.co/ doing superb mounts (much more lightweight, some sort of flexible plastic).
You’d likely want to buy the seatpost mount (they do pretty much every shape) + the gopro varia adapter.
I’ve just ordered a 3rd one today (for a 3rd bike).
Hi there, i am searching for such a mount and would really appreciate if you can share it on thingiverse.
Thanks
Hey folks, now i can offer you adapter for the Varia RTL 515/516 and the RCL 715/716.
Specialized Tarmac SL7 Garmin Varia RCL 715/716
The adapters are available for:
Specialized Venge
Canyon Aeroad
Orbea Orca Aero
Scott Foil
Steven Arcalis
Trek Madone SLR
The width of the 2018 Aeroad-Seatpost at its narrowest is about 17 mm, going wider to about 19,5 mm measured around 5 mm towards the front of the bike.
Hope this helps.
Hi, can you place your seatpost on a squared sheet of paper and draw the outline with a sharp pen? Than i can check that for you. Here is an example:
2 ways I’ve done it not even using the seatpost. Mount on saddle rails with this: https://www.amazon.com/dp/B0832LRC69
For anyone that rocks a Specialized saddle, you can also use the swat mounts on the saddle to mount a GoPro mount and then get a GoPro to Garmin adapter. It would require the above piece (or just a gopro to garmin adapter) plus this one: https://www.amazon.com/dp/B07VPFDFLQ
Advantage of the latter is that you can still run a saddle bag. I run this on my Tarmac and Slate. If you just mount to saddle rails, most saddle bags won’t fit.
I would check raceweardirect.co for something with the same profile as yours, or just ask them to make one.
Something like this: GoPro / Light Mount for Giant Propel Seatpost (2020 Model Year) – Raceware Direct – Custom Cycle Components
Then you can get the gopro to varia adapter (even add the airtag adapter if you want).
any chance for a closeup picture of how it’s mounted to the saddle?
The product i use that is available in japan is Rec Mount
REC-MOUNTS Saddle Mount for Specialized/S-Works [SWORKS-SDGP] Specialized/S-WORKS ROAMIN, POWER, BRIDGE, and other saddle holes (Dowel holes) such as ROAMIN, POWER, BRIDGE, Black https://amzn.asia/d/c2ZWpfS
