I know this is tongue-in-cheek but there’s decent logic here. Pretty sure that would force a MTB Q-Factor on the cranks though, which probably starts to change the aero equation and compatible componentry again. I’d never thought about this but I guess even more than clearance and overall geometry, it must be those 3 spindle widths that separate a dropbar 29er from just a rowdy road-native gravel bike, right? (I just looked and Mason ISO and Salsa Cutthroat both use boost hubs and BB.)
Maybe better to have a ‘crossover’ wheelset with 100/142 hubs and spare 110/148 end caps so they’re ‘gravel native’ but can also fit MTB. Or are the rotor/cassette actually further outboard on boost spacing?
What I’m really curious about though is where we’re headed in terms of rim width, and crucially what that means for sidewall exposure.
Just two years ago 3T were the only ones offering this and I ended up buying LightBicycle WR series at 25/32mm wide to save money, though both Nextie and LB have since joined the 30/40 club. But even by putting 40c tires on a 25mm internal rim I started to notice scrapes and scratches on my sidewalls that just weren’t even really a thing on my previous 21mm internal rims. Sidewall protection suddenly matters to me in a way it didn’t before. And the dings and paint scratches on the rims themselves are way more abundant too!
So now that it’s no longer wild and radical to go to 30/40 for rim width and fit a 35c tire that inflates to 39mm WAM to make an ideal aero setup, I keep looking at the photos and just thinking how much abuse those sidewalls are going to encounter. How reliable would my ‘really reliable’ tire choices still be then? (Also what does squaring off the tread pattern of something like a pathfinder really do to it’s RR/cornering qualities, but that’s a separate rant!)
And I can’t imagine we’ll stay in the 30/40 width rim realm for long if there are gains to be had by going even wider. A 35/45 width rim at 50+ depth must be just around the corner, right? So is that then a 40c tire inflating to 43-44mm? Potentially the same percentage of exposed sidewall compared to the overall tire size, but on a bigger tire that’s still more exposed surface area total, right?
Will we just have to keep defaulting to tougher and tougher sidewalls or are manufacturers eventually going to put wider treads on the same width casings to account for this? Could they even end up offering the same size tire in both wide and narrow tread width to suit different rim sizes?
I’m convinced that this is a major aspect of the MTB tire RR advantage that we’re not fully appreciating - even on a 30mm internal rim a 2.2" tire is lightbulb-shaped enough that the most delicate bits of the sidewall are shielded from most rock strikes by the tread. Is it possible that we’re just on a repeated cycle of choosing wider tires for lower rolling resistance, then choosing wider rims to suit the wider tires, then requiring tougher sidewalls to suit the additional exposure, then realising that even wider tires can be more supple (and still reliable) because we haven’t yet exposed their thin sidewalls to the same level of abuse, then beginning the whole process over again?
And separate but related: if someone were to try to leap over incremental steps and go straight to the endgame, what does an ‘aero MTB’ wheel/tire setup look like? 55mm external width and 80mm depth? Even in a MTB race there will be enough time spent at aero-relevant speeds for there to be an advantage worth exploring (as long as weights are acceptable).
OK I think I’ve calmed down now. Maybe next time I’ll spare you all and just start a podcast or something!
