Based on the graph of your 2min effort, I wonder if you might be able to hit the 400W for 2min if you started off at a slightly lower power. Maybe something like start out around 410-415W and just try to hold on. I think one key to focus on in an effort of that length is to know what gearing and cadence you plan to hold for most of it, then try to get your breathing in sync for the “middle” section.
I used to do semi-regular 500m tests on the rowing machine, which were usually slightly under 1:30. While that’s shorter than a 2min effort, I think the duration is similar enough that the pacing ideas transfer. The key for me was that steady-ish rhythm from about 15sec through about 1:05 or 1:10. After that I was definitely just trying not to fade too much.
Confirming what @WindWarrior said – Intervals.icu requires a capacitive effort, while TR’s AI FTP Detection uses Machine Learning to analyze millions of rides to understand how FTP changes over time and in response to training. Our system looks at your personal biometrics and the unique details of your recent and past cycling data to detect your FTP without the need for maximal efforts or specific workouts.
My AIFPT is 272
My Intervals.icu eFTP is 253
My WKO5 mFTP is 242
I’ve done max 30 sec, 5 min, and 20 min efforts all within the past 90 days.
I usually do workouts with the TR AIFTP prescribed watts, but when I’m not able to hold those watts for certain workouts I justify it by telling myself I’m still within the prescribed range according to WKO5 lol
I always felt like AIFTP gave my ego a nice FTP, but in reality it was higher than it should be. When I used the FTP it gave me, all my workouts felt way too hard.
WKO5 and Intervals.icu always felt like a much more realistic value. Xert on the other hand was always crazy high. I’ve been using the WKO5 numbers and my workouts feel much more manageable.
intervals.icu isn’t always super smart, I did alpe du zwift yesterday and at 25mins shifted a little into tempo for a few before I picked it back up and the detection only used the higher 25min segment (even though my 47min power was 297)
Yeah it started with interval detection but since then I have been busy with all kinds of other stuff and haven’t had a chance to go back and make that better. Endless todo list. Must put less bugs in the software
People on this thread have eFTP about right. It needs a max effort long enough so your anaerobic side of things doesn’t skew it high.
Intervals.icu tracks a “rolling” eFTP number that decays slowly if you reduce training load and goes up if you do a good enough max effort. That is the one that is used to generate the “FTP Up” achievements.
If you look at your power curve for a specific time period then another eFTP number is displayed on the chart. This is the best eFTP for that power curve.
@davidtinker Thanks for your work on intervals.icu. I dropped the paid version of Strava and I’m paying you now. It’s really flexible; nice piece of work.
Thats what success does! FYI - I tried the Garmin secondary target support and it doesn’t work with HR (as per the thread on your forum). Once I have a chance (next week), I will post full details on your forum about the missing fields in your workout.fit (I completed initial analysis comparing Garmin workout vs Intervals workout, want to start clean and properly document for you). Cheers.
This is the correct answer. Intervals.icu will give you the same eFTP if you one 3 minute interval at say 350 W or if you do ten 3 minute intervals at the same wattage, assuming the rest intervals are not super short. AI FTP Detection will take the full workout into account and understand that your FTP is likely to be higher.
I did my first long hard outdoors effort the other day since starting TR training (and intervals.icu use) in December, and intervals has gifted me an eFTP of 304W, based on 9 minutes at 344W.
My AIFTP meanwhile, taking into account the same ride (and a bunch of TR workouts, but not loads as I’ve been mostly unstructured outside riding recently) bumped up from 279W to 282W.
I prefer the eFTP number, naturally. Especially since at 75kg it sees me breaking the magical-seeming 4W/kg barrier
That said, while it’s s that time of year where I’ll now barely touch TR until October, I’d be reluctant to set my FTP on there to 304W. I think some workouts might suddenly become a bit TOO challenging!
