Hey all,
Iām sorry for not being more active in here today! Please watch the short video below for more info and the FAQ below.
We messed up on not giving you more context and information on Workout Levels and the Updated Plans. Weāre committed to getting to that to you and it is our primary focus moving forward. Stay tuned for more!
Workout Levels FAQ
What are Workout Levels?
Workout levels are a new metric in TrainerRoad that compares the relative difficulty of workouts within each energy system and training zone.
They range from 1 to 10 with some workouts even exceeding a level 10, with 1 representing an easy workout. Thus, a Level 6 Threshold workout is significantly harder than a Level 3 Threshold workout, but not as challenging as a Level 9 threshold workout.
How did you come up with them?
We leveraged the analysis made possible by our Machine Learning algorithms and the insights we have gained with Adaptive Training to accurately quantify the difficulty of any workout.
The result is a very accurate representation of workout difficulty that takes into account details such as interval repetition, interval length, interval format, recovery time and more.
How are these different from my individual Progression Levels Iāve seen in the Adaptive Training previews?
Your individual Progression Levels are a representation of your capabilities within the context of Workout Levels, and those are not yet ready for production.
Workout Levels are simply ML-driven quantifications of the relative difficulty of a workout, and those are what you now see for every workout.
Are Workout Levels comparable from one Zone to another?
No. Workout Levels are classified in two ways: (1) Zone (2) Workout Profile.
An example of Zones would be Endurance, Tempo, Sweet Spot, Threshold, VO2 Max, Anaerobic, Sprint.
Each Zone has various different Workout Profiles within it. Workout Profiles represent the interval structure of the workout. For example, the VO2 Max Zone has On-Offs, Float Sets, Sustained Intervals, Traditional, Attacks and more.
Workout Levels within a specific Zone and Workout Profile can be directly compared, while Workout Levels within a specific Zone but different Workout Profiles can only be loosely compared. Workout Levels between workouts of different Zones cannot be compared.
For example, a Threshold Level 4.0 and an Endurance 4.0 are not going to have the same RPE.
What is the max level?
There is no max level, but most workouts will fall within Workout Levels 1-10. If you are completing workouts above Workout Level 10, you are likely to gain more from reassessing and starting a new training plan at a higher FTP and lower Workout Levels.
How do I know how hard a workout is with these Workout Levels?
This understanding will come quickly as you train with Workout Levels.
For context, most athletes are able to complete a Level 3 workout regardless of where theyāre at in their training, while significantly fewer athletes tend to successfully complete a Level 8 workout unless their training has properly progressed them to that point.
Are Workout Levels personalized to each athlete?
No. Workout Levels are assigned to a specific workout based on itās difficulty, and is done regardless of an athleteās abilities.
Individual Progression Levels, an upcoming and currently unreleased feature, is what will be unique to each athlete.
Why are some workouts missing levels?
There are still some workouts missing Workout Levels that weāre working on fixing. If you find any instances of this, please share it with our Customer Support team at Support@TrainerRoad.com
Will my custom workouts have Workout Levels?
Yes, all TrainerRoad workouts and custom workouts should have Workout Levels assigned to them, but at this point we canāt endorse the Workout Levels of custom workouts.
As of now, Workout Levels are calculated uniquely for custom workouts and are not comparable to the Workout Levels of workouts in the TrainerRoad workout library.
Will Outside Workouts have Workout Levels?
Yes. Every workout in the TrainerRoad workout library will have Workout Levels assigned to them.
What is a reasonable progression rate with these Workout Levels?
Based on the data we have, anything within a 0.3-0.7 weekly progression in Workout Levels for a given Zone is considered achievable, productive and sustainable.
This doesnāt mean that an athlete couldnāt experience a 1, 2, or even 3 level increase in Workout Level from one week to the next, but these larger jumps are not likely to lead to productive and sustainable gains over time.
While there will be some individual variance between Workout Profiles and Zones for individual athletes, this progression is a data-backed approach that will yield performance gains.
How should I use this in conjunction with TSS and IF?
TSS, IF, Duration, and kJ(cal) are crucial metrics for understanding the impact of each workout, but none of them tells the full story.
For instance, long, slow rides can have the same TSS and kJ(cal) as short, more intense ones. Also, two workouts of the same length and IF may have vastly different work/recovery structures, making it hard to compare the experience of one to the other.
Workout Levels take all these factors into account in one easily understandable metric.
Updated Plans FAQ
Why did you update the plans?
We are committed to constantly improving our training plans as we get more data and insight into how to make you faster.
Our progress so far with Adaptive Training and our Machine Learning Algorithms has allowed us to quantify workout difficulty with more precision than ever before, allowing us to create training plans that still accomplished the same objectives, but did so in an optimized way.
While this is a comprehensive update, we will continue to make improvements over time as we gain further insight.
What changes did you make to the plans?
Our goal was to use the data we have gotten about workout completion and ramp rates to optimize the plans. This meant the main focal points were to optimize the progression of different Zones within each plan, and to adjust their beginning and end points in order to accomplish the unique goals of each plan and do so in a way that increases your odds of sustainable and strong performance improvement.
In actuality, this meant a very different approach that merited rebuilding the plans from scratch while still adhering to the original goals of the plans. As such, we created 641 new workouts to satisfy these progressions and goals. Nearly every workout in every plan has been changed through either being swapped out with a different workout or being shuffled to a different point within the plan.
Do these new plans Adapt to me?
No, these plans are not adaptive, just like the previous plans. This update to our training plans uses insights weāve gained from the Adaptive Training Beta, but it is not Adaptive Training.
Why do the plans start at Levels 3-5?
Levels 3-5 (roughly) are an ideal starting point for athletes starting a new plan with an FTP assessment. This was discovered after analyzing completion rates at scale in great detail, looking for what delivers sustainable and strong improvement in performance throughout a training plan.
Why do the plans progress the way they do?
This doesnāt mean that an athlete couldnāt experience a 1, 2, or even 3 level increase in Workout Level from one week to the next, but as those Workout Level increases get larger, and particularly when they are being accomplished in parallel with other high intensity Zones, they become less likely to lead to productive and sustainable gains over time.
The new plans are lower in TSS than the previous plans ā why is this?
Using TSS as the main guiding metric in training plan construction can lead to a non-progressive ramp rate in how each energy system is trained. The result is commonly a plan that looks like it ramps consistently in terms of TSS, but is far from a consistent ramp in how it trains energy systems, causing non-productive lulls in training productivity and excessively hard workouts that can halt training progression.
In short, TSS is a vague metric that doesnāt take into account the unique demands of different types of training.
Since our focus is to make you a faster cyclist, we focus on training the energy systems that matter most to your goals. Using Workout Levels to build plans guarantees sustainable and productive ramp rates that are uniquely adjusted for each energy system and the goals of the plan.
Why did you make these new plans easier/harder? How will this better prepare me for my discipline?
In the spirit of constant improvement, our goal with these plans was to make them even more effective at making you a faster cyclist, not to make them easier or harder.
There is a temptation to assume that harder training will always yield better results, but our data shows that high quality training yields better results, and āhigh-qualityā is analogous with consistency and progression.
The start points, ramp rates, end points, rest weeks and tapers of these plans are all designed to put you in the best position to improve your performance as an athlete.
The rest weeks and tapers look a lot easier. Why did you change that?
A more optimized and consistent ramp rate increases importance of the Load:Deload balance of work and rest weeks. As such, we took a measured and conscious approach to reduce load during rest weeks and taper weeks in particular.
These changes will better prepare you to be consistent with your training throughout loading phases and better prepare you for peak performance on race day.
Why should I follow these new plans?
You should follow these new plans if you want a more optimized and data-driven approach to reaching your goals. Not to say you wonāt reach your goals following the previous plans, but following the new ones will increase your chances of success in reaching your goals.
Can I still follow the old plan thatās on my calendar?
Absolutely. You donāt have to change your current training block and can finish it out to avoid manually swapping out workouts. That said, we do recommend using these updated plans as soon as youāre able.
Iām almost done with my current plan ā should I update to the new plans?
If you are in the middle of a training block and switch to these updated plans, you may notice a decrease or increase in Workout Levels compared to what you have been doing.
If this is the case, our recommendation is to substitute the workouts that remain in your current training block for workouts with Workout Levels within .5 of what you have been doing recently.
Once you finish your current training block, youāll start with a Ramp Test with the new updated plans and the workouts will once again be calibrated to your fitness.
How do I update my Plan Builder Plan to get the new plans?
The easiest way is to update your current training block through the Calendar on TrainerRoad.com. To do this, go to the start date of your current training block, click the calendar annotation with the name of your current training block, then click āUpdate Planā.
If you have any questions on this, feel free to reach out to Support@TrainerRoad.com
What happened to the weekly tips?
We are planning to remove the weekly tips as we get closer to launching Adaptive Training. Since Adaptive Training will frequently adjust workouts in each week of a training plan, the current weekly tips will no longer apply.
When will we get updated triathlon plans?
This round of updates includes the bike portion of the triathlon plans, but not the run and swim portions of the plans.
This update was driven by the data and insights we have gained from Adaptive Training and our Machine Learning algorithms, which at this point are being applied to cycling-specific training only.
Consistent with our theme of constant improvement, we do anticipate updating other aspects of our triathlon training plans, but we have not ETA for this at the moment.
My plan disappeared after selecting an update ā how can I get it back?
Please reach out to our Customer Support Team at Support@TrainerRoad.com ā theyāll be able to get things sorted for you.
Iām getting a āSomething went wrong. There was an issue updating your plan.ā error ā how can I fix this?
- This is a good one for our Support Team too. Support@TrainerRoad.com.
