Probably to fatigue fast twitch fibres.
I am really curious what my first 2-3 years of training look like zone distribution wise, but I completely avoided as much intensity as I could, only working it in once the weather was finally nice enough to ride on dirt, and did almost no planned run intensity except for races. I was trying to stick with Zone 2 back then as well, but some of zone 2 in a 5 zone model is above LT1, but still fit the bill of trying to be mainly easy work. By year 3 though I had worked up to 8-10 + hours and was at least getting some age group awards
Sounds like a good approach to me for when getting started. How much higher intensity training did you end up introducing? How did that affect your performance?
Now that Iām really looking at itā¦ During year one, I was training too hard, then I started reading the message boards and most of the suggestions were to go easier, and that is when I saw a rapid increase in training paces. Intensity was introduced as trail days. Trail running and MTB were my intensity. If I did all training on the dirt, eventually things broke down and I needed more time to recover. I am noticing that HR averages for all training trended downwards after the first season of training and paces went way up.
When I first started TR, it was my first introduction to true structured intensity and it worked really well, FTP jumped by 30 watts when talking about year over year peak, 40 watts when talking about pre-season to race-season. In year 2 my FTP was basically the same, but my power profile did change a bit increasing most 5 minute and lower power PRs, so I was still fitter and more appropriate for MTB. This year Iām getting a nice boost by trying to limit my intensity, and thus volume is increasing by being able to fit a bit more in duration, but also by increased consistency. Consistency should be factor #1 for an endurance athlete, and never do so much intensity that it throws off your consistency. Easy to say after 10 yearsā¦ not always easy to execute.
I saw on a podcast or read on a blog (honestly there is so much of this stuff around Iām getting that I donāt know whether Iām coming or going) that a training partner of Phillipe Gilbert says he just does long easy rides and then when he feels like it throws in an all out 60/90 sec efforts at crazy high wattages. He then just carries on riding easy.
Good advice. Mix it up and be consistent.
That was Hincapie talking on Lances Podcast.
@mcneese.chad Thanks for the breakdown of your experiment! It does answer my question.
Just a thought on the āno-coastingā philosophy - I wouldnāt obsess about that. The body doesnāt care or react differently to your long indoor ride if you get off the bike a couple of times for a bio break or just to rest your butt (I have to do this on long indoor rides). In the name of minimising mental/psychological load I would relax on this principle if I were you.
It could also just be your physiological makeup. Either way, itās not a bad thing, not everybodyās VO2max is 120% of FTP. Just adjust the intensity to something that suits you. Itās not failure, itās success.
I would love to hear TRās take on this and a deep-dive into this data. Iām a big fan of sweet spot training, but I do think that the high proportion of intensity in the TR plans is a risk factor, and personally I wouldnāt have as much intensity for athletes I coach for the fear of breaking an athlete (even if 90% of athletes might do ok on that same amount of intensity). Perhaps with the exception of a 5-6 h per week athlete.
For those intense workouts, I would focus more on RPE and power, and HR will follow. Thatās what theyāve done in Seilerās studies, and then they retrospectively found that on average 90% of HRmax seems to be were people land. But the training prescription has been e.g. 4 x 4ā - maximum sustainable effort or 4 x 8ā maximum sustainable effort. The duration of intervals and recoveries dictates intensity. Simple as that. So when you do VO2max work, do 2-4-minute intervals, when itās threshold-work, do 10-20 minute intervals, or do those in-between 5-10 minute intervals and simply see how hard you can go and keep the same output throughout the workout.
Iāve been doing one VO2max workout (2-4 minute intervals, 15-24 minutes work duration, 1:1 work rest ratio typically) and one threshold workout (e.g. 4 x 9ā or 3 x 12ā or some sort of pyramid) or sometimes suprathreshold (e.g. 4 x 7-8ā), and this last Sunday I raced my first half distance triathlon of the season and had an awesome race so this approach has worked for me.
Yes, pyramidal is bottom-heavy by definition. For example, my training is pyramidal, and my distribution is 85/10/5. What Seiler is saying is that itās just as bottom-heavy for pretty much all elite endurance athletes across disciplines. What changes is the distribution of work in Z2 and Z3. So it might be 90/2/8 in a truly polarised approach, or 90/7/3 in a pyramidal approach. The bottom of the pyramid is still the same.
I know what youāre referring to, but itās not exactly like you describe. This calculation is if you want to get an estimate for what your HR at e.g. 60% of VO2max is, or 90% etc. But in this interview, and in the research on the intervals etc. when they talk about 90% of HRpeak it really means simply 90% of HRpeak. @Peter this answers your question too! The table in @mcneese.chad 's table is correct.
This example demonstrated finding a HR corresponding to a certain % of VO2max.
Using HRmax is a more easily attainable and less error-prone way of doing things. Sure if you have a lactate test then you could use percentages of LTHR just as well. I would trust the HR from a 60-min test less than % of HRpeak to be honest, due to cardiac drift, condition-dependent changes in HR on the day, etc.
The best way is still a lactate test, as Seiler also says (see the comment by @themagicspanner). And I think pretty much anybody could fairly easily go and get a lactate test done. I disagree that itās ānot available to most athletesā - it is. And as @redlude97 says, getting incorrect estimates isnāt exactly a great alternative either.
Off the top of my head, Iāve seen maybe 5-8 studies in amateur athletes. Probably only 0-3 of them have been in the 5-6 h/wk range, I really donāt remember. But I think most would be closer to that 7-10 hour range.
Really great summary, I completely agree with this.
I think the 90% HR rule is a good guideline for what might be a staple HIT workout, but it doesnāt mean that VO2max-work and sweet spot work doesnāt have a place. The athleteās profile and goal event and limiters would determine how you plan out what you do in the more intense workouts.
See above. Itās the simple percentage when weāre estimating the thresholds.
Hmm, I would really question that only 60% at low intensity could possibly be the most effective way for you to train, even at 5-7 hours. Maybe, just maybe 70 might work. 80 over 60 any day of the week though if I were you. What does your training week look like? But yes, there are no āmagicalā numbers/distributions, it is a range of course, but IMO not anywhere near as big as what you suggest.
One thing that IS confusing is that he is pushing the 80/20 time distribution, rather than sessions if I recall correctly? So this actually goes against what Seiler is saying and obviously against Seilerās research.
Mic drop!
Yeah - seems like any athlete should be able to do 2 hrs of intensity a week, without overloading themselves.
LOL, thank you, and have a great weekend!
Agreed, and if REALLY pushed Seiler would likely agree. I think the problem comes about with those other 3 hours - the training should still be very bottom (Z1 in a 3 zone) heavy. Thatās where people seem to make mistakes with their lower volume is the bottom heavy piece still needs to be 60ish %, but in reality they push to 75-80% which has negative repercussions on the workouts that āreally countā.
Just listened to the sections of the two podcasts again and I can see that the numbers donāt really line up with one-another unless you do one by the absolute percentage method and the other by the range method.
And, just to convince myself, I calculated the Norwegian Zones outlined on the page I linked by the two methods:
Equivalent HR to %VO2max by the HRrange method and absolute percentage of HRmax which works out quite nicely.
Thanks for the clarification.
Mike
To give context, I train for sprint/olympic distance triathlon & 5K/10K runs. This would be a typical weekā¦
Mon:
- Lunchtime 20 min strength & conditioning, plus easy Z2 1 mile run to/from the gym - low intensity.
Tue:
- Lunchtime ~40 min run intervals or threshold run - high intensity.
Wed:
- Evening 1 hour CSS swim session - never worn a HR monitor for this, but guessing falls in moderate HR zone.
Thurs:
- Lunchtime 45 min easy Z2 run - low intensity.
- Evening 1 hour TR interval workout - high intensity.
Fri:
- Lunchtime 30 min technique swim - low intensity.
Sat:
- Rest.
Sun:
- Morning 1 hour TR interval workout, plus 2 mile brick run - high intensity.
In the summer Iād usually do a longer ride outside.
Itās not ideal in tems of spacing out the different sports, although itās the best I can do with fitting in full time job, 2 young kids etcā¦
In terms of sessions it actually falls at 50% low intensity (although that depends on how the CSS swim would be classified). Iām not sure exactly what the intensity split would look like with TIZā¦ Iāll work that out when I get more time.
After training for triathlon for 3 years, with plenty of trial & error, this is the kind of week that seems to work best for me.
The couple of races Iāve done this year have gone wellā¦ I got a PB in my local duathlon, plus ran a new 5K PB last week, so Iām heading in the right direction.
Iād be interested to hear your take on the sessions Iām doing @Mikael_Eriksson. If you think Iām doing too much intensity which workout(s) would you change?
You said ā% HRmax is exactly how the Norwegian Olympic Federation prescribe training zonesā.
Even if true (which I doubt), Norwegian triathletes donāt seem to be paying attention.
And yes, setting zones based on lactate levels is practical. You test once and you get your heart rate zones. Simple as that. You donāt have to re-test all over again in training like Blummenfelt.
And if you donāt do a lactate test, there are much better ways than using HRMax which render more accurate estimates of your HR zones. Like % of threshold, for instance.
As you can see, my issue is not with using heart rate zones but with using % of HRmax as a benchmark.
Maybe Iām wrong and misunderstood what you said, but I think what youāre talking about is calculating zones based in HRmax (such as the Karvonen method) rather than as a way to describe the zone.
The Norwegian zone model is based on a series of lab test but is just used as a guide. It uses %HRmax to describe the zones. Calibration of your particular physiology is obviously important.
Edit: Perhaps I shouldnāt have used the word prescribe when talking about the Norwegian Zones.
Mike
As s small quip, the zones used by the Norwegian federation are closer to the % of vo2 max chart. Iāll link the actual article Iāve been using as a reference but zone 1 up to 72% of max, zone 2, 3, 4 > works oot to 72-82-87-92-max. This really lines up with the notion that the hard intervals are mainly zone 4. Need to read a bit more in an article to really see how this is calculated since many of the figures show an increasing hr over the individual, and then series of intervals.
Wow great thread love this stuff! Iām a reformed tri guy who now loves xc.
Finding it hard to ride long on the road.
Just want to make training simple soā¦
Could a guy just do 2x trainer ride a week
1 vo2, 1 threshold and then spend as much time as possible riding the trails at a easier pace. Say 10-12hrs total for the week. Just want to simplify this stuff
Yep. Thatās basically the approach I take. I usually add an indoor sweet spot ride also.
I follow the low volume TR plans, swap the weekend ride for a long outdoor ride, and add either Eichorn or another outdoor ride. Or at least thatās what I try do when my schedule allows.
