Road tubeless experiences
I was able to install 25x622 5000 TL on Enve 5.6 disc wheels, and even install a tube roadside after a big gash, but then trying to reinstall was almost impossible (and I know all the tricks!).
Just bought 32x622 5000 TLs for my new Bontrager Aeolus 3V wheels (25mm internal, 32 external) and :pray: its an easy install.
I essentially swore off Continental tires years ago. They are just made insanely small on the bead diameter.
I think I went tubeless 5 years ago. It was when I got a disc for the TT bike. I had no problems with that so when my road bike wheels were out two years later I got a pair of Tubeless Hunts and ran them for a year no problem. Then on hindsight I made a stupid mistake and switched to Finish line, never dry out sealant. It doesn’t dry out in a p’ture hole either. With Finish Line you’d p’ture and continuously lose air slowly until you hit a small bump (like a cat eye) and the tyre would become unseated. I almost gave up on tubeless until I realised it was the sealant at fault.
After I sorted it I unfortunately found out I needed chemotherapy which destroyed my finger nerves and wrecked my finger strength. Not having to change tyres during that year and the ability to run them at low pressures as my wrist was constantly bruised by the chemo needle was a blessing. So much so that in the middle of it I bought new tubeless winter wheels which were surprisingly easy to set up. I am now seeing the rolling benefit of them now I am fit again. I have also hit massive potholes in a chain gang, etc carried on without loss of performance and got home to find that whilst I have lost pressure, its not been a ride ending p’ture.
I’ve had Joe’s, Stans, Continental and Muc Off and never had a problem with any just Finish line, avoid it, sounds good but is useless :-1:
I have 45mm gravel tyres on my bike pumped to 35 PSI.
When I was washing my bike I noticed a thorn in the tyre not much thicker than a needle. I pulled it out and faced the hole downwards, sealant sprayed out and showed no signs of slowing down. I put my finger on it and stuck a plug through the hole.
Does the tyre have to be spinning for the sealant to work, or should it still work by having the hole facing down with the sealant coming out?
Regards GG
It doesn’t have to be spinning IME. Quite a few times at home I’ve pumped my tyres up and that 10psi of extra pressure opens a hole and I’ve just rotated the wheel round so the sealant fills it. Maybe your hole was a fraction too big and it’d take a lot of sealant or a plug was needed.
Ok thanks. Few people suggested it needs to be spinning, so I wasn’t sure.
The hole seemed tiny! Who knows where it went wrong, but I certainly certainly thought the sealant would fill a bigger hole!
Regards
Gg
also depends on the sealant. Stan’s race sealant opened up again at pressures over 50psi in my 25mm race tires. Replaced with Orange sealant and all is fine in the deep dark woods.
This is not what I wanted to read just after ordering another bottle of Stans Race sealant :thinking:
I started using Stans Race last year on road tyres and I haven’t had any significant issues. Only time i had to resort to an inner tube on a ride was when I ran my rear tyre way too thin and it ejected a small piece of it’s tread when I ran way too fast into a pothole. My wheel/tyre combos have been easy to unmount and mount. Most of the time I can do it just with a floor pump.
In any case, road bike alloy wheelset got it’s sealant replenished about a month ago after sitting unused during the winter. The early spring road conditions here are notorious for causing punctures due to the leftover “sand” (more like fine crushed rocks) that is used to combat road ice during the winter. The bike paths and sides of the road are covered in it. In any case, the 30mm WTB Exposures worked without any issues or drama.
Now the roads are mostly cleaned up and it’s starting to get warm. I replenished the sealant on the carbon wheelset (with Pro One Addix 25mm tyres) last weekend and did two rides. I lost a little bit of pressure on one ride, but that seemed to be fixed by tightening one of the valve cores. I had replaced it earlier and probably didn’t tighten it enough.
Almost halfway through the spring wheelset and tyre extravaganza now… The town bike, touring bike and mountain bike are still running studded tyres that need to be replaced with summer tyres…
Dropping PSI weekly to get adjusted to not bumping around. 205 6 ft stalky build.
Now at 90 front 100 back. Did a 100 miles with an unplanned time trial after my wife crashed and went unconscious. Ambulance arrived took her 45 miles north. Being from out of state I had to TT in a torrential downpour 20 miles with slippery roads and wooden bridges. Glad I was at a lower psi than my previous 110 back 100 front.
Grateful for 2 years of trainer road to have the fitness at mile 80 to gun it to the car. Then gun it in the car yo the ER.
My wife landed hard and went unconscious. I NEVER want to see that again, no matter how many times it replays in my head. 7 seconds of no response is 0 seconds too long.
she has a concussion and bruised face and road rashes legs. She wants to ride the hilly group ride Saturday. I have convinced her not too.
Look. Everyone does what they can to enjoy cycling. Be it a race or event etc. tech is important but needs small adjustments and tweaks based on personal rider comfort.
My fitness meant I got to my wife earlier rather than later regardless of weight and psi. I’ll never be 150 lbs. and don’t care. I am fit and fast with years of skills. That all mattered Saturday April 24.
Glad to hear that she is fine, but after a concussion there is usually a recommendation from doctors of resting from any streneous activity a week or two. Got this info last time I crashed and hit my head hard (broke my beloved evade-II :frowning: ).
I’m looking a switching to tubeless when I get a new set of wheels, at 95kg I get flats to often while commuting.
For me, the jury is out on road tubeless. The higher air pressure and lower air volume means it doesn’t work as well for road tyres as it does with mtb ones, and I still have some concerns about being stranded in the event of a catastrophic failure. Recent threads on a few forums about certain tyres coming off certain tubeless wheels also make me wonder if safety standards are quite where they should be.
It’s an appealing concept, and I’m sure works well for most users, but I suspect I’ll be sticking with clinchers on road for the moment.
After buying my new steed this year (BMC Time Machine) I finally got around to ordering my second/race wheelset for it. I wound up going tubeless since they were out of the tubulars. This will be the first set I’ve ever owned or used after riding for…many years.
I’m having my team mechanic install and prep them for me, which takes the headache away, but I’ve never actually lived with them. Anyone have any tips for me? I’m sure there’s a long forum post about them somewhere, but I’m just looking for a few quick anecdotes and tips from people who use them regularly.
Keep in mind the set will only be raced, and I have another set of clinchers, so the whole ‘hassle to replace’ thing is irrelevant in a race situation.
Cheers!
PS-I will post a pic of the finished product this week when they are all done.
Make sure your sealant hasn’t evaporated
I saw that, but it said 2019 on the search bar so I assumed that was a dead topic. Go ahead and merge if it’s still active and you think it’s best :slight_smile:
For races, get a dynoplug or similar.
Check pressure more often before going for a ride, because they can leak a bit when new.
Other than that, just ride!
Chill out then, that’s ^^^^ the only real thing that is any worse than tubs/tubes. Once they are holding air there isn’t much for you to do just top up the air every so often like a tub/tube. Every so often depending on your storage conditions you’ll have to remove the valve core and top up the sealant (somewhere between 4 months and a year) but during that time you might have had 3 or 4 race ending p’tures with tubs/tube so in comparison it nothing.
You might want to buy some sort of tyre plug (worm) for a road side repair in the rare event a hole doesn’t seal but your mechanic will probably take care of that rare event too.
I will have a second set of wheels for a race, but some fondos don’t have support vehicles, so I might need to meddle with a flat. I’m going to be running some Specialized Turbo race tires. Any good plugs for a tire like that? I’ve never used them (but I have seen several videos about how cool they are).
I just use a heap £3 tubeless repair kit (I’ve only actually used it once in about 5 years). With my cheap one its just a case of pushing a worm in with the tool, pumping the tyre up and trimming it with a blade. I also fixed a mates tubeless disc with one pre race and it was good for a 20mins 10. Its quite quick but some of the dearer tools look neat :+1:
You’d learn a lot installing them yourself. You can read the tips in many topics on the forum.
If you flat during a road race with no sag support and you don’t have a clue as how to plug a tire, it’s going to suck. It really helps to practice it if you can.
What second wheelset did you pick? I have a BMC Time Machine as well and only have the clinchers that came with it. On other bikes, I run tubeless set ups and was a bit hesitant to return to clinchers as I have had great success not flatting on tubeless. I am now more comfortable setting up and maintaining tubeless than I am changing out tubes.
