Noise control is sometimes trick. One maker (Rockr Indoor) uses a special rubber sheet applied to the top and bottom surfaces, to dampen sound. Their owner is a “sound guy” well schooled in acoustics, so he has a better handle on this than most.
Some have used regular rubber sheet glued to the deck and bottom, but results vary.
I ended up going with the Lifeline as it was like half the price of the KOM Cycling version ($250 vs $480). So far it’s been good. No complaints on build quality. The KOM looks better IMO with the black/red paint, but they’re pretty much the same.
Only have a handful of rides on it so far so I’m undecided on how I like it. Honestly, I hardly notice a difference to no rocker. I have the air balls at around 8psi and can lean side to side to get the edges to touch per DC Rainmaker’s suggestion at getting the right air pressure. But while riding I hardly move. I don’t feel or see a noticeable rock even during VO2 efforts. I have to purposefully try to rock to get much movement. So far, it feels very similar to the trainer on the ground. Maybe the PSI is too high but I can lean all the way max if I try so I don’t know. For out of the saddle efforts, it’s a weird feeling. To me, it’s not similar to outside riding. Maybe I’ll figure out how to get a better feeling.
Yeah, I highly recommend at least testing with lower pressure. I run around 3-5psi to get a much more active feel. I am 145lbs nekkid and like low force of movement. It “forces” me to be active with my handlebar control. This lighter leveling spring force also makes standing a bit more natural.
That said, general comfort gains can happen at these higher pressures, but I find that dropping from what people often start with is a good idea. You may hate more movement, but it’s so easy to change that I really think it’s worth dropping 1 or 2 psi and testing. It’s easy to add back in if you hate it.
I have had my rocker plate for 3 weeks. First few rides took some getting used to but I dont even think about it now. I just learned to turn my front wheel slightly at times and balance is perfect. At the start I felt like I leaned always to the right so I just adjusted the air in the balls slightly and then all was fine.
I feel better on indoor rides these days. I have the KOM one which adds forward/back movement as well. I did my FTP test on it and had a bump in FTP so no negatives here.
Hey Chad, I haven’t topped up the inflation for my Lifeline for the best part of a year. I figured I’d let the pressure drop over time as I’ve got more experience with it. However I’m doing a base block fully indoors with longer then usual time in the saddle at the moment, and let’s just say I could use some extra comfort. I’m intrigued to hear more about your thoughts quoted above.
My comment relates to the saddle pressure mapping testing I did. Vid is super long, but it showed that even a moderate amount of motion present in a relatively stiff leveling spring setting can make a big difference in saddle pressure as compared to rigid. Softer settings may have improved a bit, but most pressure reduction comes from the mild motion and stiff springs.
But, even the best rocker settings are not a cure all. I still employ standing breaks (like 30 secs about every 3-5 mins) to aid the improvement from the seated rocker motion.
I did a zwift race earlier. My FTP is 340 and I found it a challenge to hold 290w.
I’ve released some air and this evening I did Whorl. That felt much better and comfortable. Maybe it was the steady state that was easier as opposed to racing and the associated surges.
Yeah, sounds like it could have been good to tweak pressure down. Many people start with high pressure because the motion feels to unstable compared to rigid. They end up fighting that “stable” setup that is actually not a great setting.
Letting air out leads to needing more actual control at the bars, but leads to a more typical use of muscles closer to outside. That and giving it a few more rides should help.
Let us know how it goes or if you have more questions. Happy rocking!
I’ve definitely embraced the softer spring settings for a much more natural motion, but short term while I’m still doing over 15 hours indoors per week, I’m going to trade a little motion for a little comfort.
Thanks for the link - nice N=1 experiment that backs up general anecdote about rockers. I think pressure (to an extent), but mainly movement is my main issue judging by some of my war wounds, so again suggests my sweetspot might be in the stiff to medium range.
Yup, despite the minimal sample size, and a biased one at that, this puts some numbers to what so many people report in my FB group. Even the most simple and minimal rocker solutions can lead to greater comfort, via the motion and saddle pressure reduction as the trigger.
There is sure a need to experiment with pressures to find what suits each rider. Personal preference, rider weight, riding experience and more can all impact what someone finds as the “right” settings for them. Takes a bit of time to play with, but I think there is a unique solution for each rider that should give them a better experience than rigid setups.
Yep, as it’s just like how what’s aero for one person, might be totally un-aero for another person. There are so many variables in this equation that it’s impossible to recommend anything other than experimentation. Your video was really helpful in understanding what the likely impacts of different pressures may be, so I feel like I can start off with my experiment not being totally in the dark.
The video really makes me wanna get fitted for a saddle too!
Yeah, that pressure mapper is quite a nice tool. Sadly, ours died not too long after I shot that video, and we have not been able to get it fixed yet. I have a fair bit of new testing I would love to do with it.
As a fitting tool, it can be valuable from the standpoint of putting real clarity to pressure points that can be difficult to discuss sometimes. I miss having it as an option, even though I only used it for about half my fits back then.
What’s also fun and interesting with it is watching the changes in saddle loading from “simple” changes to things like saddle height and front end position. You can totally transform saddle pressure with pure handlebar setup changes. It’s all part of my ideology “Any single change has multiple consequences”. The challenge in fitting is keeping all those impacts in mind and do our best to balance them to attain the desired fit goal.
