Ahh no. I had my coffee ready for my morning read of the review looking forward to it nonetheless when you get it all setup.
Some photos would be good!
So I got a pump today (yay Amazon) that I can use to blow up the damping bladders to stiffen them up. Do you have an estimate of what pressure range these should be in? When I got it, they were down around 2psi, which wasn’t surprising given this was shipped. I pumped them up to 8psi, but don’t have a clue on what range I “should” start in. Thoughts?
Picture before I broke it down:
Pressure is a function of the ball size, lateral placement from the center axis and system weight (rider, bike, trainer).
Thanks. I figured all of those factors would impact pressure, but wanted to get a feel if people are using single or double digit pressure. I’m guessing this will end up on the higher end just given the SB20’s weight, but now that I have a pump, we shall see.
If you want max support with minimal pressure, moving the balls out to the sides is the easy thing to do. You can easily relocate them to the pure front or rear opening between the decks. Install the balls wider than the precut holes, and inflate as desired. It’s just tweaking leverage and the balls will be fine at the outer ends vs in the middle. The deck and trainer are stiff enough to transfer the loads as needed. So you have lots of options to try.
Moving the pre-cut holes to closer to the edges is the only change I would make. Being closer to the edge “feels” like the correct position, as it would give you the most out-of-the-box control over stiffness / damping.
I have a turbo rocks side to side only model and I’m very happy with it - makes a big difference on longer sessions. I bought it a few months before they released the fore-aft model, and if I’m honest had that been available at the time I’d probably have bought it. But I’m content with what I have and see no reason to upgrade - so I guess it comes down to how much the extra cost means to you.
I’ve recommended them to a few friends in the UK, all happy too - great customer service.
Was about to buy the Realplate React from TurboRocks but then thought twice about additional sound / vibration / scratching sound. Would love the additional motion but I guess this video shows the real world sound:
And I think that might be too annoying for the neighbors in the flats below me or next to me…(once was told they heard some noise/vibration 2 flats below me).
Currently have a Neo and have a sound isolation plate (with sand) under my setup to keep sound/vibration as silent as possible (seems to be ok now).
Anybody thoughts/experiences? @mcneese.chad
For sure, the typical fore-aft motion from these setups adds some noise. Most use a linear bearing with recirculating ball bearings. Each and every one of those rolling in the track, and on the linear shaft add a bit of noise. There are other reasons I’m not a fan of that particular bearing setup, but we seem them as the most common in use with this rocker design.
It would be best if they switched to the linear bearing that is a “plain” bearing style with no actual moving parts. It ends up essentially silent and also removes the wear issues that the BB design above can lead to in some cases.
That said, not all fore-aft motion is like that or as noisy. The InsideRide system for their rollers and E-Flex are pure wheel bearings as a different approach and don’t add any real noise IMO.
Would instantly buy InsideRide E-Flex if it would be trainer independent and working with my Neo
Yeah, I have a “hack” I started years ago for that case, but have not finished it. Essentially, uses the stock E-Flex front end, with my won rear section for the Neo. I need a few hours in an afternoon to finish it, but expect it will work as intended. I can share more info if you were really tempted to head in the DIY direction.
Could be an option. Would be nice if you had a pic for my better understanding. (Other option might be to buy kicker at actual price)
I will try to snag a pic tonight.
No shipping outside US and Canada. Bummer.
Oh, I always forget about that. Lame sauce.
I literally dug out this thread to try and find out about the Pedivella Rocca for the Kickr.
Can I get some feedback on how well these ‘rear only’ plates work and if they deliver the comfort benefits? I had even considered the stupid expensive Kickr Axis feet as a space saving option but mixed reviews suggest they make little difference in reality? My goal is comfort and eliminating as much of that soreness we are probably all familiar with once you’ve been on the trainer for a little while.
I’m very tight on space with the trainer wedged between the rear of my ‘garage queen’ car and my workbench. A full length rocker plate makes access to the workspace pretty much impossible but this type of plate under the Kickr would be perfect.
Thanks
For the Kickr, I would go with the InsideRide E-Flex. I used that when I had my Kickr, and I loved that combination
