šŸŽ„ Sprinting 101: How to Be Explosive
No worries! That’s literally the point of the video; critiquing me to see how we can all get better. :smile:
To Chad’s point: since watching the Sprinting 101 i have been regularly doing several low-power standing sprints in each workout. Typically at recovery or endurance level wattage, instead of standing to just stretch I now instead slow my cadence down to 50-60 & focus on:
(1) pulling back instead of up;
(2) pulling back on the same side i’m pushing my leg down on;
(3) getting the proper posture so my hip flexors are engaged
I wasn’t doing any of these things previously, and as a time-crunched individual spending 90% of my riding on a trainer i need to take every opportunity to make these fundamentals 2nd nature. I believe at low cadence & low power you can spend a few seconds with this approach and get a sense of the sway motion before you have to stop due to lack of tension & lack of horizontal movement. I figure the small efforts will eventually add up when I’m able to get on the road.
I think the ā€œlow and slowā€ approach is very wise.
I was about to make the recommendation to Nate, but as I may not be the best to suggest improvements on sprinting, I held back. But since the general idea is opened…
I know Nate was deliberately sprinting with a lower gear to work on technique, instead of aiming for big power.
  • But I think the lower gearing is leading to a cadence that is too fast for him to control and learn from.
  • I think that a bigger gear, and attention on the motions (not pushing big power) may lead to better ability to focus on the technique.
  • It’s akin to the idea of working to grow cadence overall. We don’t jump right up to 110 rpm, but we work gradually at 95, then 100, then 105 and so on.
  • I think Nate can still use the bigger gear, think about the process in a slower mode, and try to get the body position along with the related motions down in a slower speed. Then work to increase the power and/or cadence a bit, while still watching overall form.
  • As with any drill, the point that the form falls off (especially if it’s due to too much power), you should reset and go back to the basics at a more controllable power and cadence.
It was not my intention to be confrontational and I will heed your advice in future. The point I was making to Ray had zero effect on his opinion anyway. And while I don’t understand his approach to new things, I suspect he knows what his followers want.
Regarding your comments on rocking motion and sprinting, I can’t say I’m on board with all your explanations. Maybe it’s because I don’t really share your enthusiasm for conventional rocker plates. I think they created false expectations. Given the difference between the floating fork and rocker plates, we now have a new point of reference. Specifically, I think the floating fork makes out of saddle riding much more practical, while still providing the basic seated comfort everyone likes. The more I use mine, the more I think they provide something elemental, though I can’t quite put my finger on what it is.
I know you’re experimenting with something like the floating fork, so I expect you’ll be able to shed some light on why it works.
