Many years ago I went to spin class at 5am. Now I struggle to get on the bike before 10am!
So getting on the bike at 6am was a huge win (mentally). And @PattyP the other reason I was happy: What PR did you hit today? - #259 by bbarrera
I think thatās key! Having lifted for a fair number of years now, itās sort of become my baseline. I can easily do three strength workouts a week beyond what would be considered maintenance without it really impacting anything else. Cycling, which I started less than two years ago, puts much greater stress on me.
Strength training has to become part of your routine, donāt force things and let yourself gradually become stronger. I find building strength very similar to building an aerobic base in a way. Slow, steady and consistent training will get you there. If itās built over time, itās relatively long-lasting and easy to maintain.
For anyone - tips on holding the barbell in a back squat position?
Iām reviewing this:
After having a sore back after doing step-ups with unloaded bar behind the neck.
Also asking for tips because back squats are in my future after having progressed thru goblet squats. Holding a 16kg and later 20kg kettlebell close to my chest was, umm, interesting, but I held form. Also did isometric holds and those were even more fun ![]()
See Squat pillars. I do high bar, barbell up just below the neck, stance is probably in the middle (neither wide nor narrow), straight wrists, narrow grip, feet in line with the knees and hips. Try different stances and grips and after a couple of month you will know what works for you. Same with the deadlift - I switched to doing mostly sumo, works better for me.
My problem is this:
Best case for me is the first pic (left). Think I need to progress from goblet to front squat and work on improving shoulder flexibility list after rotator cuff repair.
It shouldnāt be a problem if you try a very wide grip. You can narrow it once you gain more flexibility in your shoulders. The first position would result in anterior pelvic tilt and future lower back problems while second in neck pain, obviously. You donāt want either.
Shoulders down, wrists straight and grip as wide as you need so that you can have your elbows supporting the bar. You want your hands to be bending the bar around your upper back (at least in your mind) not holding it up.
Thanks, @bbarrera, a very informative article. Iām now following their podcast too.
I think his remote coaching for strength is interesting concept.
This!
It would be overkill to recommend Kelly Starrettās Becoming a Supple Leopard to learn a single movement (squat). Still, his entire chapter on how to create torque in the shoulder and hip joints makes it worth purchasing the whole book. It certainly changed the way I lift, but almost everything I do in life including sitting, standing and even something as trivial as opening the fridgeās door. Fantastic resource!
Hmm, Iāve got Starrettās Deskbound and Rippetoeās Starting Strength and will give those a look. Know what you mean about stuff like that improving your life, over the last year lately it started with kettlebell work, then Dr. Goodmanās 12-min Foundation Training, and now following a progressive strength plan.
Thanks I was in the gym yesterday and tried that with an empty bar, and it worked! Added a bit of weight (conservatively) and surprisingly was doing back squats with good form.
Glad it worked for you! I still think the Pillars are the best resource short of a personal trainer (and sometimes better than).
Sorry for a repeat but I saw a link to the ā6 main liftsā and I thought I had saved it. It had quite a few bodyweight beginner exercises to begin before building up to using the bar. Can someone link me to it again please.
Thanks in advance ![]()
and plenty of YouTube videos showing form and technique for each of the progressions.
Thanks very much ![]()
Thoughts on this plan? I have lifted weights in the past but not much at all in last 3 years. Iām trying to best figure out how to incorporate with a Low - Mid vol SS base plan. I donāt have lots of extra time for 2-a-days. I have 35lb and 60lb kettlebells at home.
Mon - First SS workout of week reduced to 30-45min then Kettlebell work immediately after
Tues - 1hr SS workout (standing zwift ride with friends that I canāt move but will focus on SS intervals)
Wed- Z2
Thurs - Kettlebells AM and then 1:15 standing zwift group ride around noon (will include some intensity)
Fri - rest
Sat - SS weekend ride (maybe a 3rd day of weights during base season?)
Sun - rest / family day
Kettlebell sets
Probably will start without much weight and then add as I can.
How do people manage their nutritional needs w strength training included in the week. On the bike kJs are easy to keep track of, but Iām curious if people feel like their food intake is significantly higher w lifting. My protein intake is higher, but itās hard to gauge how much more I need to eat.
If Iām hungry I just eat, nice and simple.
Agree 100%
5x5 is simply to much volume for natural beginners unless you are juicing or a genetic freak w/ godly recovery capacity.
I would agree this would be risky. For me I am considering 3x5 as maintenance in the base phase having completed 10 weeks of strength training and building through the phases.
