@boombang I appreciate this is an old thread but do you still have that part? I bought a second hand one and the S0010 has worn down. I can’t find it anywhere
I think I have one in my garage. Am UK based if that helps you work out if even viable to get to you?
Do you know how you remove the position block T1981.22 from the main unit? I can’t budge the axle and don’t want to force it and risk damaging the casing. Thanks in advance.
Hi All,
Hope people are still reading this old thread.
The notices in my Tacx Bushido Smart are broken too.
I do have a spare T1981.22 at hand.
But how do I replace it?
How do I remove the axle around it pivots
Cheers,
Jurgen
Post pictures!!
Will do, am on holidays
Looks like you will have to take those ends off the base and get to how that bar is kept in place. It might be held by a tab, or have a c-clip on it. You care going to have to disassemble more of it to get that part out, if that shiny steel rod id what is holding it in. It’s impossible to say how it’s removed, could be tap, could be c-clip, could be a bolt too. Good luck…
