Maybe more for the UK market as they’re sold exclusively through Wiggle/CRC but Vitus have just upgraded their Escarpe trail bike and Sommet enduro bike for 2021. Available early Nov.
Very good specs for price.
I’m looking at the Escarpe 29 CRX. See below for specs.
£3,500(~$4,500) for Fox factory fork and shock, shimano XT groupset rolling on some DT Swiss wheels
with good Maxxis rubber think is a bit of a bargain. Carbon front end, alu rear triangle.
Its certainly piqued my interest. Until now, I’ve been looking at getting an Orbea Occam on their Myo scheme but availability is poor with long wait times.
Specifications
FRAME Escarpe T700 carbon front triangle, alloy 6061 rear
Internal cable routing, post mount disc brake mounts, BSA threaded BB, Boost hub spacing – 148mm x 12mm thru axle
REAR HUB DT Swiss M 1700
6 Bolt, Shimano microspline driver, Boost – 148mm x 12mm thru axle
FORKS FOX 36 Float Factory Series 29”
Kashima coating, Grip2 damper, 36mm stanchions, 150mm travel, 110mm x 15mm QR axle 44mm rake
SHOCK Fox Float DPS Factory
Kashima coating, EVOL air spring, 3 position lever, 205mm x 65mm, trunnion
FRONT TYRE Maxxis Assegai
3C MaxxTerra compound, EXO/TR, 29” x 2.50”
CHAINSET Shimano XT M8100
30t, 170mm
REAR TYRE Maxxis Dissector
3C MaxxTerra compound, EXO/TR, 29” x 2.40”
BOTTOM BRACKET Shimano SM-BB52, BSA
73mm BSA Threaded
BRAKES Shimano XT MT8120
N/A
FRONT DERAILLEUR N/A
N/A
BRAKE ROTORS Shimano SM-RT76
203mm front / 180mm rear, 6 bolt
REAR DERAILLEUR Shimano XT M8100
Shadow plus, long cage, 12 speed
HANDLEBARS Nukeproof Horizon riser
Alloy 7050, 25mm rise, 9° back sweep, 760mm wide S/M, 780mm wide L/XL
SHIFTERS Shimano XT M8100
Rapidfire plus, 12 speed
STEM Nukeproof Horizon
Alloy 6061, 45mm reach, 0° rise
CASSETTE Shimano XT M8100
10t-51t, 12 speed
HEADSET Acros AZX-212-CO R5
Sealed bearings, OD44, 44/28.6 – 56/40
CHAIN Shimano XT M8100
12 speed
GRIPS Vitus lock on
N/A
FRONT RIM DT Swiss M 1700
SPLINE 6 Bolt Black Front, 15x110mm, 29"
SADDLE Nukeproof Neutron
N/A
REAR RIM DT Swiss M 1700
SPLINE 6 Bolt Black, 12x148mm, 29" Shimano Microspline Driver Body
SEATPOST Brand-X Ascend dropper
Remote lever, 31.6mm, S 125mm drop/M 150mm drop/L,XL 170mm drop
FRONT HUB DT Swiss M 1700
110mm x 15mm thru axle, 6 Bolt
SEATCLAMP Vitus bolt, 34.9mm
N/A
