agree 100%. I thought it was just me. I don’t want to have to manage the calendar in two places. The old scheme worked just fine.
You’ve taken an app that allowed me to get on my bike and ride to one where I have to use an app that doesn’t sync with a web calendar. This must be one of the worst updates to a piece of software I’v ever encountered.
Yeah… The Mac support really needs addressing.
Problem is for new users there’s no obvious connection between starting a plan & then following it. For current users it’s souring the experience of the new calendar.
Could I suggest that you add a quick update that simply displays the current calendar (only editable online)? This way we can select/start rides, without having to go figure out what ride we should be doing next & finding some way to load it.
I’m sure this has added massively increased functionality but I’m really unimpressed. You guys have dropped the ball with this.
Like others I work erratic hours and train regularly but not at fixed times/days. Know what plan you’re on based on your goal, open app, click on next workout, cycle, done…
Come home tonight looking forward to training. Open app and select update as is normal every few weeks and everything is gone, the interface is different and I need to open additional windows. Ended up bewildered and gave up on training and now have pent up energy and am grumpy!
Why was this released on Mac when it wasn’t ready?
Why did you change something that worked so well and was so simple to navigate and use?
Why do I need to open something outside the app? What is then the point of the app?
Why can’t I just get on my bike and ride like I used to?
Can you release the previous version of the App so we can just go back to how it was? By all means add the calendar once it is properly Mac compatible so people can explore it’s functionality and gradually use what it offers. Don’t ruin everyones experience of your normally amazing package. I just want to ride my bike! It shouldn’t be this hard.
I’m in the same boat as the rest of you. Mac user, went to load up my next workout and it is gone. Why release and force an update that isn’t ready yet?!? Went to the online calendar and dismissed the one-time-only prompt and had to search how to add the plan manually. Now - do I have to search for my next workout in the app and hope it completes correctly in my plan? Plus, why all the run and swim workouts in my plan? I train for long-distance triathlon but only follow the bike part on TrainerRoad, the rest I work out myself. Now this new calendar I’m being forced to use has all this clutter on it. Really unimpressed with this change to what has been a brilliant platform to date.
Hi Nate, I hope this update isn’t effecting your training Like lots of others I like the flexibility which was in the old version, plus it was nice and simple. It would be good if we could flick between the old version and new version functionality in the next release. Or alternatively On the plan page that still shows which plan is active, so would it be possible to let this show our training and progress against the plan.
Keep up the good work and make sure you get your training in.
Ian
Just re-added my plan, and it was relatively easy…quite intuitive actually! Only thing I missed the first time I tried was I left the end date as the default from the dialogue box, instead of selecting it for myself, like I did for the start date.
Perhaps since the training plans are a known amount of weeks, the end date should default to selected start week plus 8 wks, then if people want to change things, they can by moving it around in the calendar.
Hopefully this feature can eventually get up to a level similar to Training Peaks, and by that I mean more metrics, or more specifically, metrics that can be presented in a tidier/easier fashion than currently…TPeaks allows you to show just the numbers in a table, rather than a graph, and with monthly histories so you can see you are improving, or what aspect is lagging others, eg. 30sec peak Watts is not increasing at the same rate compared to other time periods (1, 5, 10, 1min, 5min etc).
Then Coach Chadbot can give you some workout suggestions based off that???
Otherwise, thanks for the great software and training plans, Nate, Jonathan, Chad and Team! No need to hold the five-star rating hostage on this one @Jonathan
Upward & onward!
also assigning an outside ride to an indoor event has dissapeared
I had this on my Mac too but it’s was a really easy fix, just used the calendar feature and added the phase to start on the same date as the original. It then automatically sync’d the ones that had been completed and was fine. Crisis averted!
Hi
I am also excited about the calendar feature. However, what ever I did, like others, it killed my current plan and restarted it from today. I was 3 weeks into SSB 1. I just added the workouts individually but it now appears I am not in a plan.
Is there a work around? i tried to start the plan from my original date but it did not seem to pull through the workouts, just had them as blank as if i had skipped them.
Its not a major issue, just wondering what others have done.
Damn, I lost my plan too. seems like it might be easier to just start over at this point with a new plan than manually add every single workout.
Oh really?
I suppose you remove the scheduled workout with the outside workout automatically appearing in the calendar for that day. Is that the expected process @Nate_Pearson?
I noticed this. Not a big deal but would be a good little fix.
Best thing is to either push/pull the plan in the three dot menu on the left or delete the plan and re add it.
I really liked the simplicity of the “career” and the ease to see other workouts within the plan so you could jump around depending on time or fatigue.
Could you give us the option to pick Career or Calendar?
Thanks
Scott
If you do an outside ride you can match it to any planned ride, including an inside ride.
There’s an “associate with” section at the bottom of your outside ride. Most rides will auto match, but inside/outside will not auto match. Personally, I like to not match them so that I see the inside ride as “skipped” and I see the outside ride there, but you can do whatever you want.
Hi Steve, I responded to the current state of Mac here: Calendar Mac Update - We will do better
Thankyou, that’ll do fine for the next few weeks, much appreciated.
Thanks @Nate_Pearson
