Absolutely gorgeous! Very nice UI update, subtle but significant. And THANK YOU for finally bringing back the keyboard shortcuts to the Mac
Cannot wait to try it out tomorrow!
If you need help w/Traditional Chinese translation let me know. It is not as simple as converting the Simplified Chinese to the equivalent Traditional Chinese characters.
I’m sure this will be obvious once I try it, but when you press M to go from Erg to Resistance, does it stay at the current/last resistance level, or does all the resistance fall off to some low default (which is what currently happens, and is annoying mid-interval). I would probably use M quite a bit once the Erg mode get’s the resistance dialed in on some of the middle / longer intervals.
I for one won’t be using this. But all I can say is way to go! A lot of effort in for a very good product. When my daughter goes back to school I might be able to move my bike near the computer!!!
When toggled, the resistance will go to the last known/set value - not to a default. Let us know if this isn’t the case for you once you’re able to give it a whirl.
At this point, we have not determined the complete system requirements. One major change is that we will no longer be supporting Yosemite, but since El Capitan is one version newer, you should be good to go .
@Geoff - is there a way to calculate watts at a given resistance # / gearing / cadence combo for a specific trainer? That is, if I’m using a Wahoo Kickr Gen 1 trainer, but want to do certain intervals in resistance mode, it would be ideal if I could preset the resistance number so that at say 95 rpm, in a specific gear, I would be doing XXX watts.
