Then just toss them in the trash and don’t waste your time cleaning the inside of your tires.
I disagree here. When I’ve removed my tires after many top ups and drying cycles, there is a layer of latex glued to the bottom. I think the accumulated layers does provide flat protection and also gives any liquid latex something better to stick to if you do get a puncture. I also wash the slick film out of the inside of my tires before I put in sealant so that the sealant sticks better.
Ok, I did clean some gravel tires out once. After I took out all the old dried latex and installed fresh sealant, it was like my tires were Swiss cheese with a hundred tiny holes that were all now leaking. When you rip the bandaid off, you get all those holes back.
We’re going to have to disagree then. That latex is not providing any strength or flat protection whatsoever - it’s nowhere near the durability of the tire itself and isn’t stopping anything that’s punctured the tire itself. 100% False sense of security. Add to that, old sealant is a pain for clogging valves, I’ve had it be a pain for getting a bead seated 100%, and I’ve never had a tire with new sealant that wasn’t 100% sealed and holding air / sealant in under a minute (seconds?) regardless of how much I cleaned it out.
And, if you have a tire that’s swiss cheese with hundreds of tiny holes, that’s a tire you should be replacing.
(I’m also not saying you have to blast it completely clean and strip it bare, but all the big stuff comes off fast)
Add more sealant once it gets low. How long this takes depends on things like environment temperature and specific sealant used.
You don’t need to clean out the old sealant. By the time I wear a tire out (8-12k km) there’s still negligible residue.
You don’t need to remove the tire. You can either take the valve core out and inject through that with a syringe (Luer lock syringes fit quite well on most presta valves provided the syringe is short enough to not hit your hub), or just unseat a few inches of tire, pour some sealant in, turn the wheel 180deg, reseat the bead, then reinflate.
Original GP5tl (I have a stash). The STRs seem to only last maybe 5-6k.
I think most of the variation people report with tire longevity relates to the predominant aggregate used in asphalt wherever they live. Variations in aggregate particle type/size/shape can really impact tire wear.
I have lots of wheel sets. They don’t all get spun on a regular basis so the sealant can pool. I’ll remove that chunk but not the thin layer around the rest of the inside.
Ran tubes for years, new bike came with tubeless. If it’s just a case of putting in sealant through the valve every few months, no biggie. If I’m taking tires off though
Orange Seal Regular user. From experience, this time of year I top off once a month. Lots of dry heat this time of year, afternoons at 32C / 90F. Pics from Saturday…
Remove valve core and use dip stick to check on sealant level:
