Tubeless road tire 2023
Pirelli P ZERO Race TLR might actually be the one, now that I look at them. Italian and one piece. Can only find them in 26mm right now, but I’m at least 2 months away from bringing my Bianchi outside so I got time…
I use the Cinturato tire on my commuter, in 35s. Safe as a tank!
I have the Conti GP 5000 S TR in a 32 mounted on the hookless x-wide Hunt gravel wheels and they have been great. I got six months of heavy usage in them (before it got cold and dark) and haven’t really noticed any wear. It was such a difference going from the giant gravel tires that were on it before that they seemed almost magic since they performed so well.
I am surprised no one has talked about the Challenge Strada Bianca tires. I ride them and love them. They come in all sorts of sizes and are “open tubular” style handmade tires. I currently have them in a couple different sizes and they roll ridiculously fast and have an excellent feel to them. They are the hardest tires in the World to mount the first time, but after a few times on and off they are easier. When I say they are hard to mount I really meant it. Even so, for me they are worth the hassle. https://us.challengetires.com/shop/products/strada-bianca-4/56968
I literally couldn’t get the GP5000s on my Aeolus3 rims. Took them to my LBS and the mechanic said that even if he could get them on what would I do if I had to get them off to put a tube in…
I had the same issues with my Light Bicycle Rims. Took them to the LBS and he said he had to resort to a lever to get them on and that if I have to put a tube in I’m stuffed :sweat: would like a fast tire that isn’t a pain to get on the rim. I’ve tried Vittoria but they were pretty difficult too
Maybe it’s heresy, but I’ve liked the Bontrager R3 Hardcase lite TLRs. And no problem getting them on the rims …
They stretch pretty quickly and get easier to take on an off. To mount them I use a hair dryer to get them pretty warm. It makes a significant difference.
I’ve heard great things about these, and might try them on my gravel bike once my Terrano Dry tires wear out. Only downside I can see for gravel is the lack of side knobs. For my use they are a bit too “rough”. And it seems like 30mm is the smallest size. I know wider tires are “the sh*t” right now, but I personally do not like the feel of very low pressures on my road bike. Thus the added size really don’t give me any benefit.
95% of my riding is on asphalt, but I do like the ability of adding some nice gravel to my road rides. It opens up more opportunities. As an example I have the road in the picture close to my cabin in the mountains and it’s nice to be able to integrate this into my road rides without a constant fear of punctures. This is about as rugged as it gets, most of the road has a much more compacted surface.
I have installed GP 5000 S TR tyres on Zipp 303S wheels without any tools. The fit is tight enough, but not too tight. The tyres can be inflated using just a floor pump and they hold air pretty good even before the sealant.
The TR’s I believe are supposed to be an upgrade on the fitting front over the TL’s. Ive fitted them both on hunts and prime (wiggle/crc own brand) rims no problems and as you say seat with a floor pump. The first time I fitted the TL’s on both rims was with my weak, chemo damaged hands was in the middle of my chemo 3.5 years ago and the drugs made the hands extra weak and numb but the TL’s still went on OK.
Would you call the vittoria terrano dry a supple/soft casing gravel tire? I ask because I have a similar purpose in that I have a wheelset for my road bike that I put frame limited (≥32c) tires on for light gravel/hard pack. I’m currently using Donnelly CDG 30c tubeless which have a nice tread pattern but they have a thick tread area and ride a bit like cardboard for me so I was hoping to find a more supple 30c-ish tire to serve the light gravel purpose that will have a better ride feel. The CDGs measure 31.5 on my 19mm internal wheels so I’m hoping the 31s will be true to size since I’m limited to 32c on this bike and that looks to be a hard limit. I’m also looking at the Challenge strada bianca since they come in 30c but only the vulcanized/cheaper one. Curious what your thoughts and impressions might be.
My training GP5000 are just last years racing GP5000. After that they go in the commuter stack.
Beautiful road! For what it’s worth I’m a big guy at 240lbs and I’m faster on rough pavement on 36s than I am on 32s. I used to ride terrano drys but on the road I didn’t like the side knobs when cornering. Im currently very used to running high volume slicks and at low pressure I think they are perfect for gravel.
Also Challenge makes the Strada in tubeless ready handmade. These come in 30mm
I haven’t tried that many gravel tires, but compared to all my other tires they feel very soft. An they seem to wear quite quickly. I have 38s on my gravel bike and run about 40psi with a total bike+rider weight of about 90kg. Could probably go even lower, but, as stated above, I do not like the feel of too low pressures. Did a gravel race last year that included all levels of gravel, asphalt, some single track and even some purpose built mtb trails. Never felt the tires held me back.
Compared to the tires my bike came with stock, Panaracer Gravelking, they are heaps better (IMHO). I like absolutely nothing about the Gravelkings…
Good timing, as this is the only ride ending issue on tubeless I’ve seen in real life, and it was on Cinturatos. The tread seems thick and has a nice layer, but the sidewall feels like just thin fabric. I tried a few things on this one but nothing worked to make it ride for more than a few metres.
It’s a nice and comfortable tire, but it hasn’t got any good durability. I had them last summer, looking for a similar tire for this summer.
Has anyone had sidewall issues with the GP5000 S TR? I’ve had 2 GP5000 TL’s over the past few years that developed big bubbles on the sidewalls, and I almost got stranded the second time!
I’m on the Vittoria N.ext now and like them, but I’m considering giving the GP5000 S TR a try if if I can find them reasonably priced.
You mean the threads coming out of the side walls? It never stranded me, but I’ll admit I was never cool with it either. Not seeing that issue with the Michelin Powers.
Wish I’d taken a picture. I didn’t see threads, but there was a pronounced bulge at the sidewall on 2 separate tires. Never had that experience with other tubeless tires.
