I will indeed do this. Thanks.
I am 88kg and still run tubes but I still enjoy high pressure tires. I run around 110 and never let it go below 90. I enjoy the feel and the buzz of the road. I did try 75-80 but once I had to hop over a pothole and I didnāt like the squishy feel
That is wildly high
Two pairs of Hunt wheels, both ~50mm one set running 28 mm GP5000 AS, run at 65PSI, the other standard 28mm GP5000 S TRs at closer to 70PSI. Weight ~75KG.
Whatever the SRAM app suggests. I find this works really well for me as a balance of speed and comfort versus the others such as silca.
Thanks. It seems others are in this boat. Iāve been following the Silca calculator but that appears to be around 10psi (or more) higher than Silca. I have a 120km ride on Saturday, might test out something lower and see how it goes.
Well, that is the difficulty between the two. Trying to keep parameters as close as possible yields very different results since the metrics cannot be made to be more similar to each other. It does not at all seem like different options more than making a calculation based upon different inputs. The SRAM calculator dials in the tire/rim interface more vs Silca and road surface.
Silcaās pressure recommendations vary quite a bit depending on the road surface conditions and your average speed (I reckon thatās what Silca factors in when they want to ask you whether e. g. you are a Cat1/2/3 rider).
I find that depending on the surface roughness I get different harmonics at different speeds.
I just accept that each includes different variables and since I figured out what pressures work for me and the roads I am riding, this is no longer a big issue. E. g. Silcaās speed selector is less useful to me in practice and the distinction between wet and dry surfaces makes more sense.
But to each their own. As guides they all work IMHO.
The tire pressure calculators I have tried gave me WAY too high of a pressure. Iāll take another look and see what they come up with.
Iām currently running Zipp 404FC tubeless, GP5000 25/28mm at 50 psi and I am about 68 kg. Even then, I let them slowly leak out and donāt end up adding air until they get down to maybe 30-35 and still feel fast.
While surely a TON of factors are at play, I did set a PR (and KOM) on a big ride yesterday (2 hour segment) and I donāt think more pressure what have made me faster.
Edit: Zipp calculator was pretty close. Still high, but close at least.
