Wrist based vs chest strap HR monitor
Interesting regarding the Polar H10. I experienced this when I ran with it, when I was at a higher pace it just dropped out, then I stopped running and it came back. I ordered the Verity Sense to compare, but it has yet to arrive.
I think this comes down to battery life management. By starting an activity on the watch, you are making it clear you want the better data.
Otherwise, itā€™s in a more passive mode, that samples less frequently. Thatā€™s my understanding.
If Iā€™m at 150 for over 10 minutes on my strap and my watch never cracks 90ā€¦ that isnā€™t sample rate.
I agree that it is likely because of battery management, but the discrepancy is greater than just what should be related to battery management. Show me 5 seconds late, fine. Never show me at all, problem.
Iā€™ve always had trouble with chest HR straps. I canā€™t seem to keep them in the right spot and find them very uncomfortable. I switched to the Wahoo arm strap and have had no problems. The accuracy is good enough for me.
I also engaged with Garmin, at length, about this. I have a Venu 2 that I use to track sleep, steps, walking etc. If I donā€™t start an activity (eg indoor ride when on the trainer or outdoor when on the bike) the HR data is BS. Start an activity and it pretty much perfectly tracks the Garmin chest strap output that is sent to an Edge unit.
They didnā€™t explain this to me at all and I was ready to give up and return the watch to them. Then I tried starting an activity on the watch itself, effectively parallel recording the session and bingo, realistic HR numbers on my wrist!
A wrist based meter by definition cannot ever measure s heart rate, it can only measure the pulse. The heart can contract/beat without the contraction leading to a pulse
To be fair, if youā€™re not in a hospital, anh heart rate monitor is generally for entertainment value ultimately.
Thereā€™s times I think my fenix 6 is just broadcasting a random number generator, and thereā€™s times itā€™s spot on with my polar h10. If I forget my strap on the mtb and just record from my watch, thereā€™s times Iā€™ll go 20 minutes at 75beats and then it goes straight to 150
Thatā€™s why I donā€™t even wear a chest strap.
Heart rate? Who cares!
Maybe try broadcasting your HR to TR directly so that you donā€˜t have redundant files? Thatā€™s what I do and it works perfectly on the 6X. Itā€˜s under Sensor&Accessories / Wrist Heart Rate / Broadcast Heart Rate. I use the watch indoors and outdoors this way now and canā€˜t be bothered with a chest strap.
Thatā€™s what I used to do with the Garmin 235, unfortunately for whatever reason the Instinct Solar Broadcast HR doesnā€™t appear to provide correct data unless its recording an activity.
Garmin gave me the run-around saying it was due to my wrist being in a certain position on a static bike, and a similar response when I said it did the same thing weight training. I have enough experience to have tested it in multiple scenarios and all lead the same thing of accurate data while recording an activity and awful data when not. I provided the info as feedback and got no further replies :man_shrugging:t3:
Wow that sucks. both the fact that the watch isnā€™t as accurate as your older one and the fact that Garmin was/is ghosting you. Does it change anything if you turn the watch on the inside of your wrist and a bit more on the forearm
No no, it IS as accurate, as long as youā€™re recording an activity. Location is not the issue, Iā€™m certain its sampling rate/algorithm.
Going back to data quality thoughā€¦at rest it seems good in normal watch mode. Its just when you start doing high HR exercise that it appears to then be off (unless recording activity).
Yea I meant when broadcasting HR. My bad for wording it poorly
Oh I see, yeah. Its not the end of the world, its just a couple more button presses really. But its the principle that counts! :smile:
You can make it work. Here are some things Iā€™ve foundā€¦
1.) If you have a dark complexion you will probably be unsatisfied with the performance of your wrist-based HRM. For instance, if I slide my watch up my wrist to accomodate aero gloves the HRM performance gets really sketchy. I think that is because I am moving the light source off the pale, never-before-exposed-to-the-sun, watch-shaped patch of skin to the tanned patch of skin.
2.) If you want the best data for comparison to past efforts, mark the notch you use so that the contact pressure between the light source and your skin is more consistent.
3.) For best results, wear the watch/monitor uncomfortably tight for the effort.
4.) As Iā€™ve said in the past on this forum, if you go from one exercise to another, itā€™s gonna jack up your wrist-based HRM for a good 6 to 7 minutes. If you do a hard brick, itā€™s not unusual for wrist based HRM to spike up for the first 6 to 7 minutes of the run.
I wear a chest HRM (Polar H10) but occasionally look at my watch (Garmin Venu 2) to see how it is tracking. In general the watch appears to be useless indoors when doing any sort of workout. However, outdoors it does a fairly passable job of matching the chest HRM.
For reference Iā€™m as pasty skinned as it is possible to be!
The battery in my HRM-Run died the day I posted this, didnā€™t realize it so my ride on Tuesday had no HR data which means it didnā€™t count towards training load in Garmin. Used the Forerunner yesterday and it worked great, replaced the battery in the HRM-Run this morning and Iā€™m a little worried about the o-ring so I might be looking at another option soon.
I will say this is probably the 5th time Iā€™ve replaced this battery over many years and the strap still works. If I do end up getting something else later Iā€™ll try for something rechargeable. Iā€™m already charging my bike computer, radar and headlight after every ride so it would be no problem to add one more thing.
The Vivioactive Optical HR sensor is pretty poor, always reads way under a strap by 30-40bpm normally, but Iā€™ve never ran it in the record activity mode. Perhaps itā€™ll do better then but I prefer to keep my watch as a time piece and not constantly be charging it, as I expect that record activity mode (or whatever its called) will eat the batteries.
Its really not that bad at all (on the Instinct Solar). I use mine to record activities most days and maybe charge it weekly.
I expect it will make all the difference. This is the exact behaviour I see on the other watches.
