2024 XC Bike & Equipment Thread
Custom shock tuning is where they adjust the shim stack, which in turn adjusts the damping properties of the fork. Well at least that’s the biggest, most noticeable thing they do. Basically it’s matching the damping properties of the suspension with the kinematics of the frame design.
In my experience, it’s highly beneficial if you are:
  1. Highly atypical physiology, particularly for super heavy riders.
  2. You have a shock with very limited adjustability. For example, if you had a fox x2, you probably wouldn’t get much out of a tune, because that shock has LSR, HSR, LSC, HSC.
  3. You bought a new shock that was tuned for a very different bike design, or you are putting it on a unique frame.
I live near a fox suspension centre and if you are sending something in for service, and want it to be tuned for a certain bike, they can make the adjustments for free. But if you are looking for something more unique, they charge.
I personally think it’s a bit overkill for most people. It’s only the people who are super dialed in to suspension feel (or maybe obsessed) that seem to really get the benefit out of it.
Yea, I kind of figured as much, but have doubts about if I really want a 4th bike right now. used V2 Ripmos can be had for great prices right now, same with stumpjumper evo, less that 3,500 for sure.
Thanks, that’s interesting stuff.
My case would essentially be #3, where I would be wanting to convert a SID Ultimate and SID Luxe to Epic 8 factory tune’s, when they were not made for them originally.
I’ll have to look up shim stacks and see if that looks like something that a home user can address.
Thanks.
Edit: Just found this.
Pivot Mach4SL with 120 front fork, and then get a 110 fork for racier scenarios.
That’s an option.
I recently started playing a lot with suspension and its amazing how much free speed you can get from great suspension.
I did more research last night, and it all sounds very possible. I’ll keep digging to see if Specialized’s 3p magic mode #2 is just a shim stack that I could put together with a SRAM kit (I’ve found other kits already).
Hey I’m considering the Epic 8 expert but currently have the Specialized Camber from 2018. Will this be a night and day difference? Really appreciate the input.
yes - although the camber and epic 8’s travel are identical, the epic 8 has more reach, more slack, steeper seat tube angle and is longer. This will make the epic feel very stable, and able to tackle terrain and move efficiently over it. It’ll be a night and day difference. Bike tech (especially in the XC/downcountry category) has come so far since your 2018 camber that was already at the end of it’s product lifecycle.
If I was in your shoes, I wouldn’t hesitate to make the jump to that new bike. Look for deals!
I’m getting 20% off list, I feel like that’s pretty good. Will likely make the leap. Great comparison above wish I could hit more than once! Thanks.
The Epic Evo 2020-23 model works perfectly with a 190x45 shock. I wanted to convert the bike to a remote lockout system, but at that time, it wasn’t possible to find an aftermarket SID Luxe in 190x40. So, I purchased a SID Luxe originally mounted on a Wilier Urta in size 190x45. The difference is negligible, and there’s no risk of the shock hitting the frame or anything else.
My sid ultimate new this year with 2p barely moves when locked out, if I stand up and pump hard on it maybe get 10mm movement at most. But normally its solid.
that’s the confirmation I needed - thanks!
Two things:
1: given the talk above about the ZFS-5, I just wanted to chime in and say that these are awesome bikes. I have one as well as a 2022 EPIC Evo (the latter which I consider the gold standard of XC bikes). My ZFS-5 is every bit as good as the Epic Evo, in fact it may have the edge in pedal efficiency. They are fantastic bikes and great values. I really hestiated buying this bike as I was nervous about a road company diving into the MTB scene but ultimately all the steller reviews and great value sold me. Man Cervelo pulled a monkey out of the hat and nailed it on this bike on their first try, so glad I got it. I view it as a refined, more efficient, and much lighter version of the current Blur! If I needed a bike, I’d buy one of these GX’s on sale and upgrade it to an XTR drivetrain/brakes and SID ultimate suspension (what I did). You’d have a top shelf bike at a fraction of the cost of a new S-Works Epic (it’d also be a full pound lighter than the S-Works Epic…)
2: what are everyone’s thoughts on tire choices for Park City Point 2 Point? Never riden the trail systems up there. Am I good with my existing Fast Tracks? Or should I put something with a bit more bite on? Atleast up front?
Point to point is the most fun face I ever. You’ll be more then fine on fast traks. I used it last year with a renegade in the back. While the course i 99% single track nothing is more then a blue.
Funny you should ask. I’m having the same question about tires for PCP2P. I was all set on Aspens until I heard the race director on a podcast specifically saying Aspens are a poor choice. So I’m reconsidering.
Ironically I’m also considering a new frame. The Cervelo, the new Epic 8 Evo frameset, and the Allied BC40 are all in the running. There are some Epic 8 Evo Experts on sale for 30% off. I have all the parts to essentially turn this bike into a high end Epic 8 Pro, for $3500. I’m just not sure what I’ll do with the wheels, drive train and suspension. I can probably sell them for $700 or so, and if so, I’ve got an Epic Evo for basically the same price as a Cervelo. I’m leaning towards the Specialized due to the in frame storage, which I am a huge fan of.
Local bike shop sale?
Yes. LBS. And technically the sale doesn’t start till Friday but . . .
30% is a great price, is this Spec thing or LBS only?
The Cervelo is on sale if you can find your size. That being said, will that bike be back for another season? Haven’t really heard a lot of future developments.
Really? Source for this info? That’s 2/3 of a lb!
