3 days to sync with Connect...are really too much
I’m wondering why TR need 3 days to push the workout to Connect Calendar. To mee actually doesn’t work but i’m trying to understand why. In general my complain is that 3 days are too much. When we recognize the need to go outside is the day before i.e.
Moreover will be nice that the training proposed is pushed to Connect Calendar with the option to be modified. Not always on the road there is the possibility to respect the timing and often i use the option “to lap pressure”. We only need to respect the working time and the recovery but sometimes we need to move from a climb to another and we need more time between the main sets.
Don’t know about Garmin Connect. But with Wahoo, when you change your plan, you just need to select the “Sync” option on your head unit. Wahoo then goes out to TR via your cell phone and updates the head unit with your current TR calendar. You can do this anytime, so long as you have cell service. Is the Garmin ecosystem not capable of this?
With Garmin and TrainingPeaks you change your plan in TP and it instantly shows up on your Garmin calendar. Turn on your bike compound it syncs and the workout is ready to use.
Same with intervals.icu
with TR, according to manual, you have to select the planned activity as outdoor and wait that is pushed into the garmin calendar. i’m not talking about indoor training. For the indoor training i use the TR workout page as Rouvy is not yet sync with TR. I deleted my subscription to Zwift. I need a way to have the workout that once is available as training in garmin i can push to my edge or forerunner and modify, so outside i can follow the trining proposed. Prob. i was not very clear in the original post
I think you meant TrainerRoad
Not sure if I’m misunderstanding your question but I never have to wait more than a few minutes for my outside workouts to sync to Garmin Connect and then to my Garmin device. There have been plenty of times where I’m getting ready to ride outside and realize I didn’t mark the days workout for outside, I’m always able to change it to Outside in TR and as long as I open Garmin Connect and turn on my Garmin then in a few minutes or less the workout is ready to go on my device.
If it’s taking you three days for that to happen seems like something isn’t working right?
In the past TR downloaded the next 3 days from TrainingPeaks. And then synced every 2+ hours or something. I know that in 2020 and 2021 when I changed a workout in TP just before an indoor workout on TR, I had to (usually) force TR to redownload.
Not sure if that was part of the original post or not.
First, let’s make sure that when entering your Garmin login information in the Ride Sync settings, you are doing so manually. In the past we have seen athletes using autofill which led to them linking with the incorrect account by mistake.
Secondly, it’s important to note that workouts scheduled more than 3 days in advance will appear as “Scheduled for Wahoo/Garmin” but won’t be available for syncing just yet. Please check if the workout falls within this timeframe.
If you are still unable to push workouts, let’s have you disconnect from Garmin Connect via your Ride Sync settings and wait 48 hours to reset the token between GC and TR. After 48 hours, reconnect your Garmin account and your outside workouts should push over.
Replay from TR support…
I think you have mis-read “more than” for “less than” there.
It doesnt take 3 days to sync - it just doesnt try and sync workouts that are more than 3 days in the future.
When it works it should work straight away - in minutes.
i tryed with training scheduled tomorrow (wed) and nothing appear in the calendar right now. tomorrow training falls within 3 days.
now i’m trying the last chance
I’m sure support already had you check this… but have you got all these ticked in the garmin website settings?
Yes it was, but now i cannot post the screeshot as i disconnected TR from GC waiting for the famous 48h, let’s see. Quite annoing.
Really frustrating - I hope you get it fixed :+1:
