I have always loved incorporating strength training into my life. It’sa difficulty balance with riding and wanting to get stronger. Add work and other life obligations, it can become a lot.
I used to ride 4x a week and full body strength 2x a week. With chads help I’ve made immense gains in my comfort with a rocker plate and I have a huge desire to get even stronger.
I’m playing with 2x full body a week 30-40min sessions followed by a ride. Usually tempo/ss
Curious if my plan is effective to have some benefits for the bike
Bench press 3x8-10/incline bench
Lat pull down/seated row 3x 8-10
Shoulder press 3x 8-10/face pulls
Abs
Bulgarian split squats 3x6-8
Single leg rdl 3x6-8 l/ hyperextension glute focused 3x12-15
Clamshells 3x15
I’m trying to get out of my head that I need to destroy myself with weights to gains. Can 30-40 mins of heavy lifting benefit me for body comp and the bike gains
Thanks for your time in replying!!! Yes I do have dumbbells and kettlebells. You are so right. I will incorporate them for sure. Amazing for stabilizers and overall conditioning!!!
I would move abs more toward the end. That way your core isn’t cooked as you’re trying to do heavy Bulgarians
This sounds like a whole lot to try to squeeze into 30-40 min. It gives you like 2min max per set. You might find that you can lift heavier and with more quality if you either do a bit less or give yourself more time.
If you’re pressed for time supersets work really well. They might incur more fatigue and so use supersets wisely.
Me personally, I only use super sets for the upper body if I’m pressed for time. That way I can focus more on compound lifts for my lower body. Doing leg supersets I doubt you could do Sweetspot afterwards.
