Hi,
I’ve been doing 2x20m threshold / 3m rest for a while, and just did my first 3x20m/10m.
The only reasons I do this workout are to increase my FTP, and because I love those types of efforts.
It helps me gauge my effort too, which is really useful since I really want to get into time trials ( although this is not in my priorities for now ).
But now I wonder what would be the next step of this workout.
Is making this workout tougher necessary to get a better outcome out of it ?
If so, should I reduce the rest duration or add another 20 minutes ?
Or maybe add it to a longer ride ?
This is one of my 2 weekly intensity session, and is the least intense out of the two ( the other one being sprint or 1 minute efforts with 1 minute recovery ).
I’m following a plan I make for myself using what I learn on the internet.
How would sweet spot be better ?
I know it has pretty much the same physiological adaptations while producing less fatigue, but is there something else that would make it more interesting ?
Also, not having a power meter, the couple times I tried sweet spot I found that I struggle finding the intensity to stay on.
You could follow Chris21. Only needs three workouts: Raymond, Gray, Hour Record. That’s all you need for >4 W/kg, apparently!
I think when we first discovered Chris21’s ride feed he was only doing Gray & Hour Record. Lately Chris21 has been doing Raymond to start the week because variety is the spice of life.
I know my heart rate threshold is around 175bpm. If I go above, like 180bpm, I quickly feel that it’s too much and I won’t be able to finish the workout.
But when I try sweet spot, I struggle to know if I ride at a too low ( tempo ) or too high intensity. I struggle finding the spot
2x30, then you can go longer like 1x45 or 1x60 or you can divide the workout into shorter intervals and do more of them. I really like 5x15 (a lot TiZ). You can also mix and match and do threshold with power burst (as hard as you can) every 2-3 minutes. Of course there is also a case of 4x20 or 2x40 (it was very hard).
Interesting.
He only seems to do those 3. But its weird too. Most of the rides are off power. Like he has TR open but he let Zwift (or another app) control the power. Is all very strange.
Yes it is evil workout that is why I recently started to do 5x12 with bursts and 3 min breaks. Nice, stimulating and mentally easy. I could do easily 3x20 with short bursts (so more Leconte style) as one of 3 threshold workouts in week so it is perfectly doable - especially closer to the end of training block.
Could keep stretching the intervals out like others said. There’s a chart Fascat has that shows what each category rider could shoot for in terms of sweet spot duration per ride, could use a similar idea based on target event/goal duration. I use that chart to build up to the duration in both overall time and then into one interval.
Another thing would be to do longer rides to burn off a bunch of kJ first then do the intervals at the end. Even without tracking kJ it’s not hard to do. Just keep pushing the intervals further back in the ride until you can do them at the end before a cool down.
3 x 20 already seems pretty intense to me, but I guess you could try and increase the interval duration for the same total time. Like 2 x 30 and work up to an 'hour of power’s.
I wouldn’t go too much overboard on increasing the total time at threshold, because that can place too big a strain on your body. Maybe add extra Z2 time at the end, or trying to hit the intervals after you’ve done some Z2. That could provide an extra stimulus without impacting recovery that much.
Because I’m a @empiricalcycling fanboy, Kolie chats in 2 episodes on FTP. Long story short, training at FTP helps build FTP. Gives a few examples (eg over-unders, surges during FTP, etc)
My own progression getting to 3x20 , 2x30 or 3x25. Then throwing in surges and shorter duration + higher power and effectively moving more towards Vo2, Anaerobic, 8-10’ at higher upper end of FTP, then will re-test.
For me the “sweet spot” is 97%. You do not go over and below FTP a lot with power fluctuation. At the end of block I go by feel, usually ending over FTP.
My best block with biggest gains was 2 weeks of 3x VO2 max per week and then 3x threshold per week + 1 Z2 ride. This combination pushed my FTP by 20W and my TTE to 60 min. Also huge fan of Kolie Moore and since adopting some knowledge from podcast and articles I have moved my FTP by 45W in 3 months. So it works
What % of FTP is SS and when does it change to threshold. I would have thought 97% would be more threshold than SS. I done a 60 min today at 90% of my FTP power but maybe I should be doing a higher %.
Fascat zone chart is where I got the 83-97%. Here’s another article from Fascat’s Frank Overton that says 84-97%. Just depends who you follow it seems.
Following you guys recommendations, I think I’ll go for 2x30 minutes then.
Doesn’t seem like a big leap from 3x20.
About throwing in surges, one of my objectives is to be able to do this workout :
2x 2min vo2max, 3min sweetspot or ftp , then 5min rest and redo 2m/3m.
So maybe in the threshold workout I could throw in some 2min vo2max to start with.
I don’t know how many I should do though, that will take some trial and error.
