Looking for an upgrade to my Roval Terra Cs for my Crux. I’m planning to keep the Rovals for a road setup, but want to get something a little more race focused for dirt. After a recent top 10 I’m about to go Dylan Johnson on this bike and try to find every marginal gain possible LOL.
Trying my best to stay south of USD 1500 if possible.
Hunt Aero?
Elite Drive G45?
Anything else in this ballpark?
Light Bicycle and Nextie both make wide 40-45mm depth rims. I have a pair of the LB WG44 rims on DT240s, they’re ~1400g, cost under $1500 and I’ve beaten the hell out of them with no issues.
Zipp 303S. 45mm deep, 23mm inner width. I have a set for my road wheels but a lot of people use them on gravel. I went slightly shallower and wider with the Hunt Gravel X-Wide (35mm deep, 25mm IW).
I recently picked up a pair of 9velo GV 35 2.0 and they offer a 45mm variant. Quite light, with DT-style ratchet hubs, and Sapim CX-Ray spokes. They are oos at the moment, but available again in August, apparently.
That is almost an exact copy of the DTSwiss GRC 1400 (the old model, not the new one published two weeks ago). The only difference is that SwissSide has now downgraded the hub to DTSwiss 370; earlier it was the same 240 as the GRC 1400. I believe the rim is the same that the GRC 1400 used. DTSwiss and SwissSide have a long history together.
I don’t think it is a copy, I reckon it is a jointly designed product. To get rid of the stock they have before releasing a new one, they put it on sale. 1,000 € for a quality carbon wheelset from a well-respected wheelset sounds like a good proposition.
Yes, my understanding is that SwissSide does the aero design and DT Swiss hubs, spokes, etc.
That’s quite a big downgrade on the hub - 370 is a 3-pawl hub rather than the awesome ratchet hub you find in 350 hubs and up. I’ve known a few 370 hubs seize up.
The upgrade kit to convert to ratchet internals isn’t too expensive though:
Just a few notes regarding the Elitewheels DRIVE wheels. I’ve tested the road 45mm variant, and they are the most responsive wheels I’ve tested. They are lightweight, stiff, and decently comfortable. On the other hand, the quality of the bearing is questionable. After about 3000 km, I started to feel they didn’t roll as smoothly anymore. Some of my viewers suggested cleaning the bearings and applying a new grease. I am about to do it soon, as I already have spare bearings in case things go wrong.
Thank you @ABG, I am here to help anyone that wants to look at the Nextie NXT45AGX series wheels.
They are as mentioned a 30mm ID, 40mm OD and 45mm depth and have been on the market for a long time. The rim profile is solid and a lot of manufactures are using a similar designed rim
Depending on your goals these rims may be perfect for customers!
