Bike: Factor One V2
Saddle: (old beloved) Selle Italia SP-01 Superflow Carbonio
Seatpost on bike is similar to BlackInc.
When I install saddle it sways back and forth by 2 degree. I found that 7x9 mm saddle rails is too thin to fit to 7x9 mm (!) saddle clamp. The rails width is OK. But the height is not enough. Clamp bolt tightened with manufacturers torque: 12 Nm.
You can see about 0.3 mm gap between rail and clamp ear.
I tried following:
- Tapes: insulation, duct, galfer, friction, cloth. All of them are too pliable and squeezed off from clamp after one hour.
- FinishLine Carbon paste. Clamp started to creak. Still rocking about 1 degree.
- Motorrex Carbon paste (without particles). Silent but sways about 1 degree.
- I still not tried “beer can shim” because I have no idea is this safe or not.
- Contacted to Factor. “Do you have 7x9 saddle and use 7x9 clamp - Yes - We’ll send you replacement”. I got absolutely same clamp with same problem.
Has anyone had the same problem? And hopefully solution? Any ideas will be warmly welcomed.
