No squeak here. I’m using the Shimano SH-56 cleats with the M4 pedal bodies.
I’m using the Xpedo cleats with CXR pedals - no squeaking, works fine.
I tried Shimano SPD cleats but they were harder to get out of, it felt like something was grabbing when I unclipped.
Are there any pedals that are still being sold that work with the Assioma spindle? Pretty much all of the ones mentioned in this thread seem like they’re sold out.
CXR, Trvs Duo, Baldwins, M-Force 4, I’m having trouble finding any of these (and I’m starting to get tired of waiting for the more expensive SRAM X-Power).
The M-Force 4 is discontinued, so that one will be hard if not impossible to find. I’m pretty sure it works with the M-Force 8 as well, but they are pricey. The CXR and Baldwin are in stock on Xpedo’s website in a few colors, so it should be possible to find them somewhere if not direct from them.
You could investigate this option and report back
Hi everybody,
iI bought a left assioma spare axle a week ago and a pair of XPEDO M3s. Changed the axles, which is the only thing that needs to be done - or? After changing the axle and tightening the screw-nut the play from left to right dissapeared. What was left is the vertical play on the side of the axle close to the crank . I measured both axles (favero and xpedo) and found out that the favero axle is measuring 0.39 Inch while teh Expedo Axle measures 0.47 Inch. So the play to me looks like something you just cannot avoid. Reading through your posts it seems to me that I am the only one with such a play in the pedal?
M-Force 3 pedals have a different bearing system to the M-Force 4 and 8s and aren’t compatible with the Assioma axles.
Mike
So to sum up, the following pedals are compatible with the assioma-hack:
M-Force 4
M-Force 8
CXR
Baldwin.
I thought the M3s workout as well as GPLama shows the hack using the M3s,…
Just checked out the @GPLama video. He used the M-Force 4 bodies. The M-Force 3 pedals use a bushing rather than a bearing which is why you’re finding that the axle is a different diameter.
Mike
I’ve just ordered a set of M-Force 8 to see how they go with the conversion.
Great - I appreciate your effort! Thanks!
The iSSi Flash III (3-bearing) pedals make a flawless swap.
The Bontrager Comp may well be another possible pedal. That’s only based on appearance and the 3 cartridge bearings it uses.
Are you satisfied with the ISSIs - never heard of them here in europe.
I find them much easier to clip into than the Xpedo M4s. A bit heavier would be a neg. for the weight weenie. Think iSSi is a QBP house brand (Quality Bike Products).
Thanks for checking the Issi pedals. I have a pair and was too lazy to check this weekend. I also have a pair of Nukeproof Horizon CS pedals that should work - same axle, three bearing set up and like Issi pedals, easy to remove and replace o ring seal. I doubt the Horizon CL would work since the pedal body is likely to far inboard.
CS might work as long as there’s enough room for the “power pod”. CL definitely looks like there isn’t enough room.
The CS may be to wide as well? Pics below of the bare spindles / pedal bodies for comparison. You can see how close the pedal body of the iSSi is to the power pod. Also one of the iSSi trail pedals (which was the test mule).
Found this example of the Xpedo M-Force 8s and they had the same issue I found with the M-Force 4s, the inner seal wasn’t tight.
Here are links to the various ref images. I used the Favero seal and end caps for the iSSi Flash setup.
Top two pics for pedal spidle/body fit and the last pic shows SPD cleat interface and design. CW from upper left: XT, M-Force 4 CR body, SRM spd, iSSi Trail with Favero
Was anyone able to confirm whether or not the Ritchey pedals shown above will work for the mod?
Also, there are several Wellgo pedals that have the tapering axle that look like they could work, even a platform pedal option. Here are a couple from the Wellgo site that look like they could work, but there are more that look similar:
https://en.wellgopedal.com/products_detail_5_437.htm
https://en.wellgopedal.com/products_detail_5_430.htm
