šŸŽ‰šŸŽ‰šŸŽ‰ Announcement: Personalized Custom Training Plans! šŸŽ‰šŸŽ‰šŸŽ‰
You can still add polarized plans like you did before.
You also still have direct control of your training days. Can you be more specific about what you’re looking for?
As an aside, I’d like to be able to choose the workout duration based on zone, such as 1½-2h for sweetspot, 1-1½h for threshold, 45’-1h for VO2 max, etc. Probably another situation of me being an edge case. :laughing:
We don’t have a good way to plan for your ultra marathon right now. If there’s a good amount of time between them, I would do a ā€œconservativeā€ training approach on the bike while doing your marathon training (if you want to keep some cycling fitness).
Then do probably switch to a demanding or aggressive approach and drop the running on your way to do the ultra.
I suggest this because you’ll be accustomed to a lot more total training stress overall, even if it’s not cycling. I bet your body adjusts quickly to the new stress.
Correct, this is a display bug that we’re fixing (or might have already fixed).
But as you go through your plan you’ll get different workouts.
Same response as above. They will adapt and switch as you go through your plan.
I want to be clear, the plan DOES taper as you approach your event.
There’s a display bug that doesn’t show it on the plan originally, but as you approach your event it shows on the calendar. Sorry that I wasn’t clear about that.
Man, you are brutal.
A very large team of talented and hard working people built and tested this.
This is the most complex area of our code, and we made some mistakes. None of us are happy about it and all of us want to make it better and improve.
All of those people I mentioned are working hard to fix it.
We’ll get together afterwards and figure out what we did wrong, and how we can improve it so we do better next time.
Again, I’m sorry about the bugs. There shouldn’t be so many. We’ve already fixed a lot of them and will continue to fix them.
You went hard enough to trigger a red day. Red days have more to do with your recent training history rather than one particular day.
So although you might have just barely gone harder on that day, you might have done more (or maybe less long term) leading up to it.
We agree and will add it back.
In general we have two audiences:
  1. Forum athletes
  2. Non-forum athletes
Forum athletes are power users and wants lots of customization and ability to self coach/tweak.
The non-forum athlete is more using us as a coach where they are assigned a plan and they complete it.
We dropped putting the entire plan on the overview section because I was thinking of serving #2 and that group #1 could still look at it on the calendar.
I still wonder if requests will die down over time after they use this feature more, but nonetheless, we’re still going to add a sample back to that page.
We’re looking into this now, sorry about that.
Yes, that’s the real way to solve that. Sorry that isn’t done yet.
oooo, like if you manually add a training block to your calendar through the training phase. I don’t think we’re going to add that in, it’s a little too niche and not the direction we want to go in.
Polarized will get this update later. We need to finish fixing some current bugs first.
We’re going to have a whole new AT system coming out and I think you’ll be able to do this with it.
Hi Nate, thankyou for hearing the feedback. Yes it was direct. The sustained effort from the entire team is appreciated.
@Nate_Pearson just to give you some other feedback from a regular forum user (it’s becoming 6 years):
I’m always happy to see new functionality and the :tada: :tada: form posts. Even if the new functionality has bugs and it needs a month or two to iron out the bugs. I just like to see new things TR :wink: .
I’ll give my feedback and critique where needed (hopefully constructive) and really appreciate and enjoy seeing you on the forum since you are the only one speaking on TR vision and future functionality (per your own policy) and unfortunately it’s become a little rare seeing you here (except when new features are announced).
Don’t be too harsh on yourself, keep it up and I’m looking forward to the day when there will be generated plans with max 1 day intensity per week and WLv2 will be released…
This sounds cool!
Okay here’s an idea if you’ll be so kind as to entertain it. :pray:
What if, in the interim, say an athlete’s circumstances change that day & they have more (or less) time to train. Next to, or under the load workout button, they’re presented with a button to change the duration.
Some will use it to say, ā€œYo, TR! I have more time to train todayā€ then they select a duration, then AI looks at the next 14 days planned, finds the most suitable alternate for a different duration & presents it, or shows a RLGL forecast & says something like ā€œThe training load from this duration is expected to negatively impact your next n key workouts. We recommend the current duration, or shorter if possible. Are you sure you want to proceed with a longer workout?ā€
Or the athlete is saying ā€œHey TR, I’m time-crunched today. What’s going to hit the same systems & give me the most bang for my buck?ā€
Takes the thinking out of selecting alternates for those unfamiliar with the purpose of that particular workout. Or for those who are unexpectedly time-crunched.
But please don’t take away the manual selection of alternates! :pray:
In my example below (yes I was naughty training on a red day yesterday :flushed: :laughing:), or in the situation of someone on a recovery week, it may also suggest something like ā€œHave a day off the bike today & use the time to get ahead on [insert randomly-selected cycling/health-related ancillary task here].ā€ Or not-so-random: if the athlete has repeatedly cited sleep in recent struggle surveys, it could tell them to nap, or to go to bed earlier tonight. :wink:
Thanks for sharing that @Nate_Pearson, that’s awesome. It feels like a real next level for planning once it’s sorted. It’s great to see the team is ambitious about building hard but super useful new features.
I’d be curious to hear about planning window vs phasing as well… currently depending on the window (1, 2, or 3+ months) I give CTP, the plan is either consecutive build phases (for 1 or 2 month plans), or a base, build, speciality cycle (for 3+ months). So very different training. I’ve read a couple other comments above that sound related. When the dust settles on the launch, is the goal for the planning output converge on a ā€œtrue optimumā€ independently of the planning window? Meaning will the planning be able to be based only on training goal, previous training, and events if any, or will the planning window always fundamentally alter the planning & training approach? If so, might be helpful to have CTP provide some guidance on how to think about that when asking for the planning window. Thanks, JT
I deleted the Plan and re-created. All good. The product is fantastic and ever improving.
I’ve lost track, a little, of issues that people have raised, which ones @Nate_Pearson has acknowledged as valid problems to be fixed vs. intended design, which ones may now have been fixed, which might still be outstanding…
So, at risk of repeating aspects of my initial post on this thread regarding how CTP didn’t work how I’d expect it might, I’m going to re-describe what seems off when I use the new wizard:
1. The volume suggested doesn’t seem to take particularly good account of my history. This might be because it very heavily weights the immediate past vs. it ā€œzooming out a littleā€ and considering a longer timeframe:
eg. I did significant volume across the spring & summer - lots of double-digit to mid-teens hours/wk, 400-700 TSS/week, culminating in a cycling trip late August where I did 2x ~25 hrs/week, 700+ TSS.
That trip was largely easy riding (mainly v low intensity), but I still took a little time off after returning, and have just this week begun adding structure again.
Also, the plan I had CTP build is future-dated by a month (begins in early Nov), so there’s not yet any actual activity data for it to see in the month prior to the plan’s start date.
=> Do these two things explain why the volume suggested by CTP seem low, if I follow the recommended ā€œBalancedā€ approach?
For example, the following is what CTP spits out for me as a Masters plan under the 5 different Training Approaches:
    Aggressive:    6 days    8:00 hrs   395 TSS
    Demanding:     5 days    5:00 hrs   267 TSS
    Balanced:      5 days    5:00 hrs   267 TSS
    Moderate:      5 days    5:00 hrs   267 TSS
    Conservative:  4 days    3:45 hrs   211 TSS
Also Note: each of Demanding / Balanced / Moderate all give the same result. Not sure if that’s intentional? Definitely not intuitive.
慤
2. The ā€œTraining Approachā€ and ā€œWorkouts per Weekā€ setting don’t seem to work independently, which is unexpected and limiting.
For example, building on what I’ve shown above, if I opt for the ā€œConservativeā€ approach’s custom plan as a starting point (4 days, 3:45 hrs, 211 TSS), but then use Settings to change ā€œWorkouts per Weekā€ to 6, I get this:
…which as you can see from the list above maps directly to the ā€œAggressiveā€ approach’s plan .
Or, if I go back and use the slider to actually opt for an ā€œAggressiveā€ approach as the starting point (6 days, 8:00 hrs, 395 TSS) but then use Settings to change ā€œWorkouts per Weekā€ to 4 (eg. I’m requesting similar ā€œaggressiveā€ total volume/load but now spread over fewer days, ie. give me longer duration workouts!), I get this:
…which as you can see from the list above maps directly to the ā€œConservativeā€ approach’s plan.
The upshot of this is that ā€œTraining Approachā€ and ā€œWorkouts per Weekā€ seemingly cannot be adjusted independently of each other, in the manner you might expect. Of course, you can’t really have a Conservative plan operating over 7 days, or an Aggressive one over 2 days, but there’s a middle ground surely where there’s some independence between these two settings?
For example, what I expected to be able to do was direct CTP to give me a reasonably aggressive plan comprising 4 workouts/week, ie. asking for longer workouts on those 4 days. But no matter the ā€œTraining Approachā€ starting point, as soon as I use Settings to change ā€œWorkouts per Weekā€ to 4, the plan I get is simply a Conservative plan equivalent (4 days 3:45 hrs 211 TSS).
Again, apologies if these issues have already been acknowledged and/or work is underway on them!
