I am looking to get a Ant+ dongle for my iMac running Catalina. I looked on Amazon and they’re quite a few to choose from. Does anyone have an recommendations? How far with the signal travel? I see some come with an extension lead
I have two like this style. I know @anon20047708 bought one so maybe he can give some feedback. I use an extension for one but not sure it is totally necessary in my situation.
I couldn’t find @ericallenboyd one on Amazon UK. This ones seems to have good reviews. To be honest I thought the Catalina end might be more of a problem than the dongle end.
Definitely get the extender. I was getting dropouts until I did so. I didn’t care because I use the file from the Garmin 1030, but it was vexing to see my Zwift guy pull to side of the road while I was pushing pedals.
I’ve got an old Suunto (~4yrs), and it’s been fine on my MBP. The extender cable is mandatory for a reliable connection. The aluminum casing on the machine can block the signal if it’s between the transmitter & the dongle (always in my setup). I hang the dongle on the extender cable below the machine for a clear path to the transmitter. On the bike, the path from power meter to head unit is relatively clear, and is much closer so is more reliable.
I just got a cheap generic one (actually, two, because reasons… they both get used though and both work) from Amazon, along with the extender. I plugged a hub into the end of the extender so I could put both of the ANT+ dongles in from one extension.
I have a 2014 MacBook Pro with the Garmin USB dongle and a 10 foot extension cable to place it directly under my Wahoo Kickr Core. No issues with dropouts. I use ANT+ for my Garmin HRM also.
Thank you for posting this one. Now all the ANT+ dongles seem finished all over the world with so many people training indoors during the Corona epidemy.
I recently upgraded to Catalina on my MacBook Pro from Mojave.
Since the upgrade I have had issues with BT and ANT+. I rode on Sunday and both signals completed disappeared. I had to unplug and replug in the extension cable for my Ant+ dongle to get it working again.
Has anyone else had this issue? I had no issues at all using ANT+ or BT when I was using Mojave.
I just deleted app.apple.finder.plist and the bluetooth.plist, hoping things will be ok for tomorrows ride.
Hi, I’ve Big Sur too and I can’t connect my smart trainer via ant+, its very strange because the system recognize my ant+ dongle (I can see it in system info), and in Zwift during the pairing I see the ant+ symbol is on, but can’t find the devices. If I do the same with my other win10 pc all works fine. Anyone have possible solutions?
