ANT+ Issues on Android OS 10 Galaxy Devices
I have a been using the TR app on my phone, with a USB ANT+ dongle to communicate with my Kickr, HRM and wahoo cadence sensor without issue for some time. This week, after the newest Android software update to v. 10, I get a message that the the TR app has not been updated to support his function. Do you intend to update the TR Android app to support USB ANT+ with Android OS 10?
Sounds like something is a bit funky after your update.
Can you install the ant+ tester and it will tell you which system components you are missing
Looks like I am not missing anything.
Indeed. I suggest you contact support directly. support@trainerroad.com
Edit: Out of curiosity… is it a 1+? Mine and my wife’s both got android 10 updates today so it’s a little coincidental :smiley:
Galaxy S10+
Just got to test my 1+ 6T on Android 10 and it’s seeing ant+ devices without issue.
Hey @nebregman,
We have been seeing some issues with the ANT+ after updating to Android 10 and we were able to reproduce the issue in-house.
The development team is aware of this, and are looking into a solution. Sadly, we don’t have a workaround at the moment, so if you are able to pair with Bluetooth, that would be your best option.
If your sensors are ANT+ only, then pairing via the desktop app and an ANT+ stick would work, as would pairing with a different, non-updated Android device.
We’re really sorry for the inconvenience and we hope to roll out a solution shortly :+1:.
Thanks. I have an older Android device that hasn’t been updated to Android 10. I am going to use that until I hear that this has been resolved.
I IPBike use this with my Samung S7. It has been pretty good.
Just an FYI for the dev team - TR on my fully updated S10 running Android 10 can’t see ANT+ sensors.
Hey everyone,
We have not quite cracked the ANT+ issue on Android v.10, however, it is possible to revert to Android 9 in the meantime while we continue to dig into this issue.
I’m sorry we only have a workaround at this point, I will post updates here once we have a fully functional solution :+1:.
Just to provide a little clarity, this bug is only happening on Samsung Galaxy devices. ANT+ should still be functional on devices from other manufacturers which are updated to Android 10 - if this is not the case, please let us know! :slight_smile:
Good to know, wont update my phone for now
+1 to being affected by this on Samsung Galaxy 10 SM-G973F on Android 10.
If I can help with diagnostics/beta testing please let me know.
Otherwise I’ll follow this thread for updates.
Good luck!
+1
Can also provide diagnostics/beta testing if needed.
+1 to Samsung/TR ANT+ problem. My Garmin chest strap (ANT+) no longer reading in TR after I accepted software update to my Samsung Galaxy S10 over the weekend. Not sure if there is a way to get the Garmin 735XT to feed to TR instead of directly from the chest strap.
You can broadcast it in ANT+.
https://www8.garmin.com/manuals/webhelp/forerunner735/EN-US/GUID-0C4E7DFB-E1C4-4EA8-885B-4DF88B3CD341.html
You don’t want to use the 735xt wrist HR. That’s why I got a chest strap in the first place. It’s so inaccurate. I’d recommend downgrading
I just wanted to say I have the exact same promblem. My Note 10+ was just updated to Android 10 and ANT+ no longer pairs in TrainerRoad Software. Hoping for a solution soon from TR soon :slight_smile: Keep up the great work TR!
Did a little digging. It’s happening to zwifters too and apparently it’s a garmin library issue rather than so much a TrainerRoad issue
