Poked around the wiki and source code, is there somewhere to ask questions? Its very basic - why do I have to manually give a workout name? Here is what happens after import:
Installed 3.5 and then upgraded to latest stable dev 3.6-rc3.
Seems like GoldenCheetah/src/FileIO/FitRideFile.cpp might be a good place to teach GC how to extract wkt_name and populate into GC database. But my coding skills are weak.
Latest GC looks a LOT better than earlier versions. Some interesting features.
But I can’t get past this stupid workout name issue after pulling in the last 3 years of Garmin FIT files. This is such a minor yet severely annoying issue. If I import WKO files (if possible), will that help? I did try importing TP export first.
Strike that, I spent 30 minutes last night and reviewed the FitRideFile.cpp code and FitSDK docs. Instead of starting a random “could you add this please” and pray, I’m going to add a call to decodeWorkoutTitle(def, time_offset, values) at line 2992 in FitRideFile.cpp and then use the other decodeXXX methods as an outline to make my own. After looking at 3 or 4 examples its pretty easy to see how to make my own method. So then I’ll have a method that can read the wkt_title, and can post to the list asking for help on how to write that to GoldenCheetah’s workout json or whatever they use.
Problem solved for my own needs, and I can submit a patch and maybe they will add it to GoldenCheetah official release.
