I have some Unos but have never needed to use them with TrainerRoad but I may have to soon. I read that the software doesn’t double the power so you end up displaying only the power from the unit. I also read that Favero supplied some users with a firmware file to overcome this.
So, at the latest pedal firmware does this situation still exist?
I’ve asked Favero but they haven’t replied yet.
Thanks.
For the Uno, we will take your power reading and double it when pulling it into TrainerRoad. This is true for all versions of the firmware.
For the Duo, as long as you have updated the Favero to a firmware version 4.04 or newer the pedals will send a combined L/R power reading over both Bluetooth and ANT+
When paired with TrainerRoad, we will take your left pedal’s power and double it to account for the fact that you have only one pedal paired. This all happens automatically, and there should not be an option to “double the power.” Our Devices Tab is already automated to do this for you.
So your power will not be 50% low, not 200%, but just right
Alright, so as I mentioned, TrainerRoad doubles the power automatically.
During testing, we discovered that TR cannot “sense” if the power has already been doubled or not, which means that if you double it in the Assioma app, it will be quadrupled in TR.
So do not enable the “double power” option within the Assioma app, and you will be good to go
I’m as un-technical as any geezer out there. I just attached my Uno to my crank, paired it on my iphone w/ TR and started pedaling. Power output on the phone matched my Garmin head unit, so job well done. Never even knew it was happening
