@furiousferret had an interesting suggestion in a different thread:
IMO, there’s needs to be a hybrid mode, where its ERG at Zone 5 and Below, and Resistance over. (Hint
Hint)
Would it be possible & practical to have a “Hybrid” or “Blended” trainer mode that acts in ERG mode below a certain interval intensity, then switches to Resistance mode above that intensity?
Alternatively, it might make sense to have the trigger set based on a time duration. Swap from ERG to Resistance when the work intervals are less than something like 30 seconds.
The unspoken, and driving reason is the typical response time for a smart controlled trainer. That is a range of a few seconds to more in some cases, and that can be one reason that ERG is not ideal for the shorter intervals.
- Additionally, there are issues with large jumps in resistance in some workouts. As such, shifting the gears on the bike in Resistance mode, is often a better solution.
I know it would take some new programming, and determining exactly when the mode would switch and reset will take some discussion and planning.
The current 8 and 20 minute FTP tests do this, but they are swapped based on a time in the workout, not pure intensity.
It would also be interesting when looking at work / recovery intervals that are short and/or very large jumps. We might need to set a time threshold where this hybrid mode would activate.
Anyway, I know the devil is in the details, but I think there is something in the concept.
