I have stages single sided crank vs tacx neo and the stages always reads higher, even more than would be reasonable for the difference in location. Iāve suspected maybe Stages reads higher than other meters or higher than ātruthā. We have 2 data points, if others with stages and some other meter reply maybe could confirm the theory.
Likely need a lot of data to confirm. I have the same set up as you. I have compared data files from tracking the stages on my garmin and the tacx neo on the TR app. Stages over many many rides would average 5 watts higher. More or less 2% higher or so.
I think there may possibly be a couple of things happening here.
Firstly, if both systems have the potential to be +/- say 2% or 3% accurate then the overlap between that variance could account for some of the difference and also explain why the tracking is an identical curve.
Secondly, it is perhaps a positive takeaway that they are tracking identical shapes (albeit different value) power curves as this strongly suggests both devices are at least behaving consistently on their measurement, which is really important in terms of you being able to have confidence in the repeatability and reproducibility of the data in terms of how it represents your efforts on any given ride; of course acknowledging that the actual values shown are different (but to which you can adapt / work around if needed).
I have a stages LH crank meter. Iāve noted that it consistently (for outdoors) reports about 5% to 7% higher than the power I record on my (indoors) Wattbike atom. So my n of 1 experience correlates with yours in as much as it suggests different devices record different values and whilst clearly the indoor / outdoor scenario is different to yourās (the whole indoor / outdoor differential has been covered multiple times on the forum) then the takeaway point for me has to be:
āDifferent makes of power meter record different power values for the same effort exerted.ā
Armed with this knowledge, you just need to understand if the difference is consistent or not. Youāve done that piece of work nicely so I think your all good.
Simply note the difference and move on with your training / pacing accordingly with the relevant mental āadjustmentā in mind.
By way of example; my indoor FTP is currently 306. So when riding outdoors I mentally adjust this up to circa 320 and that actually works perfectly in terms of when I need to use my power meter readings to pace an element of my ride.
Equally when post ride analysis comes into play, I can downward adjust efforts recorded, to ascertain for my TR Wattbike sessions how my riding compares and again, that seems to work really well as well.
This looks like almost every power meter comparison Iāve ever seen. One reads higher and one lower. DCRainmaker has shared tons of these. Nothing unusual.
I used to do the same as I suffer about a 15% differential between my indoor Garmin Vector PM and my outdoor Stages PM, but outdoor workouts with Adaptive Training lead to incorrect data being fed to the algorithm for PL adaptations and the new FTP Detection will also be affected. Not as simple as doing some mental arithmetic any more unfortunately.
Iām suffering a 15% discrepancy between my Garmin Vector 3 pedals (left side only) and a Stages Left PM. Looking at a lot of data points on climbs etc, and normalising for wind over several efforts and comparing them to online climb calculators, I think Stages is more accurate. Currently working through the issue with Garmin tech support.
Left side power meters take one reading from one side, then multiply it by 2. I have a stages left crank power meter and it reads about 10 watts higher than my garmin rally XCs. When looking at my cycling dynamics I use my left leg more at lower intensities and when I go into higher intensity my right leg works more. Thatās something a one sided power meter canāt record. So itās expected the ftp numbers to be different.
EDT: you have two left sided power meters but one thing that throws my garmin off is the pedals arenāt tight enough on the cranks.
My discrepancy is across all intensities and pretty consistent at around 15%. Itās a sensing issue - I just need to find out if itās cause by a hardware fault, which is what im working on with Garmin, or something more systemmic with the PMs I have.
That is a big discrepancy for sure. And I agree that as the power meters are both L+R=total meters, and I assume your L/R balance is around 50/50, itās unlikely that either PM is mechanically faulty.
Iām assuming its the crank lengh setting somehow - but I dont know how.
Could you post the cycling dynamics data from the Faveros? torque effectivness, smoothness, power phase etc.
I was pointing out that in most analysis of multiple meters, I do not see that. They are extremely similar and move as one, they just have different bases.
Thatās what your picture shows too.
My point was not that I disagree that this is a huge difference. I agree with you there. However, I donāt agree theyāre useless. You either choose to use one indoor and one outdoors and have different FTPs, or you adjust the bias and make them equal.
This absolutely jives with my SB20 experience. DM me if youād like.
@smlring The workaround, which blows goats, is to change the crank length in the StagesPower app and 100% always-always-always zero reset the cranks in the app before starting anything with TrainerRoad.
(In my case, I run 172.5 crank length and sadly have jacked the app setting to 175. I have a crap-ton of experience with PMās and know my RPE intimately. Bottom line: the power balance and RH crank on my SB20 is whackadoo. Yes, I have licked the batteries clean, etc. etcā¦ No, Stages has not responded one iota to a service ticket logged on their site). This is not my first rodeo.
Iāve tested my Stages gen2 against a Tacx Vortex, Wahoo Kickr, and a Powertap hub. The Tacx is wildly inaccurate. My Kickr constantly reads 5-10 watts higher than my Stages. My Powertap hub reads 5 watts lower than my Stages.
Yes! Personally, I just think itās a fools errand to try and train with multiple power meters. Use a single power meter indoors and out. Same bike, same power meter.
If you really really have to use two different ones then you need to test and validate them against each other and then adjust them to read the same (assuming you even have this feature).
I donāt know. Itās been a race to the bottom on price with power meters. This might be a valid point if people were still buying SRMs for $2,000. Even living with an SRM was easy for people - needing to send it in every couple of years for battery service and calibration.
A fair observation and duly noted. My own point is that despite this, what people seemingly report experiencing is that different makes of PM do in fact vary, which I guess is the disappointment that underpins what youāve noted
I have compared my Neo2 to Assioma Duo and Power2Max NGEco with all three running at the same time. All three agreed to +/-5W at 250W. I have also compared my Kickr Bike with the same results. I have never seen a 50W difference. I also have two sets of Assiomas and 2 NGEcos and they all agree with each other. I would guess that the SB20 is the problem. Especially because I have read about weird behavior where the user had to change batteries, calibrate, pray a lot, etc before the SB20 behaved. SO, that would be my guess and maybe Stages support can help. Also, if you can compare the Assiomas to something else- another trainer or PM that would tell you is they are working correctly.
In general regarding my Stages gen 2, using fresh name brand batteries have been a huge improvement.
I used to buy cheap Amazon 10 packs of 2nd tier batteries (Panasonic or whatever). Even an Amazon non-retail blister pack of Energizers werenāt great (maybe fake?).
Since buying some fresh, retail, and expensive Duracells my performance and calibration has been much better and consistent. I also bought a retail pack of Energizers and they were good.
