I’ve always struggled with the “normal” cadence range of 80-100 rpm. My rides (even in the flats) are more like 70-75. Put me the mountains where I live and it’s more like 50-60s (even in a bike with a maximized granny gear).
Whenever I try to increase my cadence I find my mid to lower backs hates it! I then gravitate back to grinding.
I don’t all of a sudden go from a 70 rpm ride to a 85, I’ve tried gradually increasing it as well.
I’ve tried a bunch of things like bike fitting, regular core training with a good personal trainer, etc.
Problem with the lower cadence is that I am muscle bound verse really working my cardio. I seldom really feel it in my lungs.
Thing is I am doing 100+ km rides through mountains and it’s pretty taxing (left hip bugs me too…sigh). I think the hip wouldn’t bug me so much if I could bike at a higher cadence.
Has anyone experienced this and solved it.
I am 48, I bike around 3,500-5000 km a year. FTP = 215.
I see you say you have had a fit but was that a fit like a BG/retul or Precision? When you’re grinding I reckon you may be more upright than when you’re spinning so a 3D fit may be the place to start.
I had a pro bike fit (laser fitting), cameras, etc. from a full time fitter. While I can say it’s likely not the fit as I feel pretty comfortable too. Position is mid-range. Not a pro/areo/TT position, but reasonably forward.
Tough case, as I think you have covered all the primary issues that should be reviewed.
What’s interesting is that I usually find the opposite result to yours (backs hurt with low cadence / high power). That condition seems to results from the extra strain on the body to control and harness the higher force exerted through the lower body.
So, I don’t know if I have any ideas, but will follow with interest and add something if I get any ideas.
Could you try this at a local gym. Find a reclining / recumbent bike. Do a session on that and take your cadence up and see if you get the same problem.
I would honestly think and from races I have done. Lower grinding cadence is harder on my back than spinning. This is interesting. Hopefully you can figure it out. I have no advice other than bike fit does seem to change a little in real life vs being fit on a trainer when not going hard. Both bike fits I have had done were done at easy/moderate effort. I feel like when hammering real hard in real life/races bike fit changes.
I do find the grinding fatiguing on my back, but that’s a different a totally different feel. That’s a long term fatigue. The high cadence is an immediate feedback saying I hate this.
Same here. Grinding uphill in the snow at 40-50rpm puts a lot of strain on my back. Spinning is much easier.
To the OP - do you bounce much when pedaling at higher cadence? When I started road cycling, I used to, as coming from MTB, I wasn’t used to cadences in the 90-100 range.
Making a concerted effort to work on my pedaling technique really helped. Kick and pull, not just mashing the down stroke.
I think it is something you just get used to. I did a Sufferfest plan last year which had a cadence build session every week. I used to be comfortable pushing 75-85 rpm. When I did intervals of 130+ my back would be sore the next day, but over time those muscles got stronger.
