Iβm currently on a plan and want to change to Masters. Can you simply change the plan to Masters or do you need to start the plan over?
This is from a TR email announcing Masters plans: ββ¦ you can switch your current phase on your calendar to a masters version. Just click the phase name in the upper right corner, then select the appropriate masters plan block in the dropdown.β Thatβs what I did when I changed mine. Good luck!
Hey @holdfast_fw!
I see youβre about to end your current training plan, so probably best to wait and set your next plan to a Master one
However, thereβs more info here about Masterβs plans and how to change to them:
