(Can’t think if I’ve started a thread similar, sorry if I have!)
Anyway, another workout tonight, initially things ok but as things progress I’m finding that the latter intervals have me pedalling like a manic to hit power. I think then the higher cadence makes things even harder to bring to balance.
I’ve used training peaks to display the cadence increases here. 5x10 minute intervals.
Presumably you are using ERG mode (based on the “power match” comment in the title)?
Are you watching and attempting to control power directly, or simply trying to hold a particular cadence and letting the trainer & app control power?
The two are different in practice and one can lead to more issues.
I strongly recommend ignoring power and focusing only on holding a steady cadence. Let ERG and the system do the work.
If you start chasing what you see as “high” or “low” power by altering cadence, you will cause problems, not solve them.
This seems even more common with PowerMatch in the mix as it complicates the process and may well add delays to the response time.
It would have been interesting to see what the power would show if you had restricted your cadence instead of increasing it.
It’s entirely possible that the trainer was responding slow, and could have hit the target power if left to adjust.
However, maybe the trainer and/or the app (via PowerMatch) could be experiencing changes due to heat buildup or other factors, and leading to different power control later in the workout.
The only time I ever purposefully slow cadence in ERG mode with Powermatch is if power being maintained by trainer is above target. Slowing cadence by 10 or so temporarily seems to get it to re adjust. Otherwise I just hold cadence around 95 as much as possible which is (now) comfortable for me and hope for the best
I tried focusing on cadence last night and not reacting to the power numbers, I just let the turbo and software do its thing, it’s not without it’s challenges but the main intervals seemed to align better as the session wore on. The first interval after a recovery bit is not always that great but I think I’ll stick with this way of thinking and see how it goes.
Not sure if my sessions are visible but here is a screen shot of what I did last night, the power lines look good and the interval breakdowns are pretty close to target for the most part, some under, some over.
Nice work. Based on the pic, I’d say you are doing better with cadence focus.
Yes, adjusting to the increase in resistance at the start is a bit tricky. You fight the power a bit and it alters cadence. It creates a short yo-yo effect but you just want to work on holding your preferred cadence it it will settle down.
Keep up the good work, I think you are pointed in the right direction now.
