Been in the new bike for two weeks now and have noticed a clicking sound while pedaling. It’s only when I pedal and feels like it could be left sided but can narrow it down. I took it back to the shop and they couldn’t get it to replicate on the stand but tightened everything up anyway. I had a ride around the car park and it seemed to be gone. Yesterday on a long ride it was back for the entire time.
I don’t want to do any damage to frame it groupset but if it’s all tight and I cant pinpoint exactly where it’s coming from I am not sure what to do next. Any one have an issue like that before
It can be maddening to identify a click or a creak, but a few less-obvious culprits to check may be the rear skewer/thru-axle, seat rails/seat clamp and the seat post/binder area. I recently had a similar issue on a new bike that I believed may have been the crank and addressing all of those (re-greasing the rear thru axle, tightening the seat clamp on the saddle rails, and cleaning and tightening the seat post binder) solved it. Unfortunately I did all of the foregoing at once, so I can’t narrow it down more specifically, but I wish you luck!
Seconded. What sounds like it’s coming from the crank or BB can misleadingly come from elsewhere. Mine was the actual saddle - it seemed to be the left crank when putting down power, but after much trial and error it turned out to be the extra force that put on the saddle itself, causing it to creak. New saddle, problem solved.
Does it depend on the gear you’re in? Had something where a badly adjusted front derailleur made the cage contact the crank arm, but only when fairly far down the cassette.
Try the headset! I’ve had the most annoying knock when pedaling that I was convinced was from the bb. Mechanic eventually found an issue with the headset.
Thanks for all the replies. Think I will just go through the whole bike and double check everything again. Hopefully I can stop it. Once you hear it you can’t unhear it for the entire ride
Make the noise happen when standing up, this eliminates the saddle. Then make the noise happen hands off the bars (or just barely touching) - eliminates the headset/bars. You’re then left with the pedals/shoes, crank set and BB. If you have a pair of completely unrelated pedals and shoes, swap those in, and you’ve eliminated most of the causes. Assuming it’s not the classical front derailleur cable end, of course.
I recently had a issue where the joint between the carbon and metal on the crank arm failed. It was really small at first so it was impossible to figure out. After a few more rides, some “play” developed at the joint and I could wiggle the crank side to side. No amount of bolt tightening made a difference. I don’t expect this to be your issue but add it to the list of possibilities!
Definitely not the FD cable. Checked that last night and it’s right out of contact with anything else that moves. Going to work my way through the list
Had a trainer session last night and it was as loud as ever. Still couldn’t pinpoint it. Might film as I pedal and see if anyone can help narrow it down. Everything seems tight and as it should be. Just don’t want to be doing any damage
