Coggan’s Physiological Adaptation Chart
I hate to ask, but I’ve tried searching and still haven’t found a good explanation of how to read the chart or maybe I am too dumb.
I understand the overall what the chart says but I don’t know how your supposed to read it.
Thank you.
E
From left to right are training zones ordered by intensity (exercise stimulus)
From top to bottom are components of exercise physiology (result)
The number of x indicate how much one of the components is changed by training in that zone (effect size)
Happy to answer because I really like this chart.
For example you don’t have to train at VO2max intensity (stimulus) to improve your VO2max (result). And training at tempo has also many positive benefits.
Arguably the worst and best type of colons.
Trying to do sweet spot 2x20 two to three times per week certainly burned me out and kept me fatigued as a non-supplementing masters athlete. It may work well if in your 20’s or early 30’s.
Thank you for the answer! I didn’t know if there was something more to the x’s.
At that time, SST was fashionable, but now many athletes train POL. There are various opinions about the placement of x in this table. And, it would have been better if sustainable time for each zone was included.
It would be great if that chart also took duration into account. You can train at endurance pace for many hours, and still recover fast. But most people cannot do more than 2-4 x 20min at threshold, and would need substantial recovery. So how much time at endurance pace would you need spend before you achieve more than a threshold workout etc
This is an interesting chart. As someone using TR, it seems to validate the sweet spot focus inherent in the plans. However, how does this mesh with the supposed gains of the “superior” (if you have the time) to train polarized? It seems the z2 adaptations are comparatively low
… but you can do a lot of it without hitting the issues around plateauing / fatigue / burnout that you take your chances with when you try to replace it with a lot of sweetspot.
As others have stated, this chart shows the ‘benefit’ of training at various exercise intensities. It is not showing the ‘cost’. You need to weigh both together to establish a function training plan.
A key part of the chart is the word “expected” in the title. The chart in the original book was very interesting for generating discussion and the authors (and others) used it to talk up SST. I have version 1 of the book but am now curious if the chart has been updated in later versions and re-writes and how well supported the data shown are. e.g. has data emerged to support the expectations.
FWIW, I think the SST proponents have added quite a bit to the training discussion. There is no doubt that 1-2 threshold (or SST) workouts each week can help an athlete hit strong FTP numbers. That said, for myself, while a block or two of SST/Threshold is a great sharpener, I do much better over longer periods focusing on mostly Z2 with one hard day (Threshold or SST workout or time trial race) every 7-10 days. My power numbers at race pace are just as good on Z2 training while my recovery, enthusiasm and ability to repeat day after day and be consistent are much better. Everyone is different though so best to try different programs and find your sweet spot (pun intended)
-Darth
The 2nd and 3rd editions of Training and Racing with a Power Meter have the same table of expected adaptations, and no column for sweet spot:
“Table 3.2 lists the primary physiological adaptations expected to result from training at each level, although these will obviously be influenced by factors such as the initial fitness of the individual, the duration of each workout, the time taken between each interval effort, and other factors.”
The guy that coined the term “sweet spot” is Frank Overton of FasCat Coaching. Going back to duration of workout, his sweet spot training plans will have you doing a lot of zone2 endurance work. The intro of some FasCat podcasts is a Frank soundbite “I was always an advocate that you could accomplish more with sweet spot training than riding in zone2 alone.” Emphasis more than “riding in zone2 alone” (the long slow distance or TR Traditional Base 1 concept).
Point being, there is value doing Zone2 Endurance work despite what you see in Coggan’s table. Maybe Inigo San Millan needs to do his version of expected adaptations.
For those new to this stuff who are curious, here is a podcast where Frank describes how SweetSpot concepts were elaborated. He gets into some of the points upthread regarding dose (time of a workout) fatigue, recovery and how to think about training.
The SST discussion starts around 12-13 minutes in and is a good story.
I’m a fan of ISM’s approach. Would be fun to see him address this!
as a starter, add two rows. Something like this:
Adaptation Zone1 Zone2 Zone3 Zone4 Zone5 Zone6 Zone7
Recovery Endurance Tempo Threhsold VO2max Anaerobic Neuromuscular
Glycogen sparing, increase fat as fuel + ++++ +
Lactate clearance ++++ ++ ++ ++
or something like that.
Yeah, the original chart didn’t include sweet spot, so imagine asking the questions about “Why ever ride zone 2? why not just ride threshold every day?”
The answer is the same as when you include the sweet spot column.
I kinda hate this chart because it’s the reason we get people on MV plans asking if they should substitute a tempo ride for the zone 2 ride between threshold interval days because MOAR PLUSSES.
Or even need this chart.
I don’t blame Coggan at all. It’s just that this gets waved around like you said - without context - and it makes it harder to explain to people why you do certain things. “This chart shows I should ride SST all the time!” Sure, go right on and do that.
I think you’ll find that some of the very best exercise scientists disagree with the allocation of the hypothetical benefits of this chart.
It’s stunning how many people take this single chart as the gold standard. Actually, basing ones entire training philosophy on a single chart is beyond madness…
This chart and especially the w/kg chart have lead many down the wrong path.
They both need to be burned in a furnace,. Not because Coggan is wrong, they are just next to useless without context.
I’m going to publish a chart with a bunch of stars next to eating cake…
:cake: = *****
Five stars, that’s way more than all the zones.
I think you should be careful extracting too many conclusions from this chart, especially without context. According to Frank Overton on his FasCat podcast, he was involved early in the power meter training revolution. I think he said he was a “beta tester” of these ideas, and he contributed to the birth of sweet spot training.
Personally, I’d be very cautious labeling one approach as clearly better or clearly worse. I have incorporated both in my last two seasons, and in my experience they emphasize different aspects of your fitness: sweet spot training did way more for me to raise my FTP (not just FTP, the number, but the actual lactate threshold as verified by outdoor rides and workouts). Polarized training did not raise it by much, but I gained the ability to suffer through really hard workouts and manage long times close to threshold. E. g. starting from last November I frontloaded a 6-week polarized block before starting sweet spot base, and by late winter, I was able to do sweet spot 8–9 workouts without any issue.
That’s also something that is completely lost in the chart: working in particular zones has a reason and a purpose that is not evident from the chart. Z1 and Z2 look like zones you should avoid, yet we know that they are absolutely essential components of training.
And at the end of the day you are not interested in physiological adaptation, I don’t care how much “Interconversion of fast twitch muscle fibers” (to pick a random column) is stimulated — I want to be faster on the bike!
We should also keep in mind the state-of-the-art changes with time. So even if — hypothetically speaking — there was clear and now universally accepted evidence that polarized training is superior to sweet spot during base phase, Coggan’s approach was solid: he tried to find out how to systematically improve training on the bike when you have this newfangled thing called a power meter at your disposal. When you don’t know, you have to make educated guesses — hypotheses, and then see how they fare.
I see where you are coming from, but I think you are going way over board here. I would say anyone who bases their training on this single chart and forgets about the context and e. g. Coggan’s and Friel’s works, methods which have been refined by coaches all over the world and applied to thousands of athletes of all abilities, is simply lacking the necessary knowledge to create their own training plan. Good coaches, including ones that prefer a sweet spot approach for base training, do not content themselves using W and W/kg as the be-all-end-all metrics for cyclists.
The issue starts when regular people, non-experts, want to base their training off of these ideas, and do so without a coach. FTP and specific FTP are the simplest-to-understand metrics in cycling. Especially in the beginning when you go, say, from 2.5 W/kg to 4 W/kg, it is almost without question that all other relevant performance metrics will have improved for you, too. But the higher you go, the more subtle it gets.
In the end, the solution is not to burn valuable knowledge, but to make an effort to learn what you need to learn — or find people you trust who help guide you.
Even in my late 20’s that type of protocol is only really useful when I am trying to sharpen up for a race for a few weeks and that’s it. Otherwise, longer then that I burn out as well.
