Can anyone provide advice on cross compatibility for Shimano rotors? My gravel bike has Shimano SM-RT99-A-SS IceTech Disc Brake Rotor - Centerlock - 140mm. They’re quite below spec for thickness after 15k+. These are proving a bit hard to find. If I go with another 140mm center lock Shimano, such as the Ultegra, will they be compatible? I expect to need to open up the calipers and likely reposition the brakes themselves, but I just wonder about the distance from the center lock seating on the hub and the location of the rotor itself.
Many thanks for any advice from someone more knowledgeable.
