I have a new road bike and I replaced the existing compression plug (one of those short fsa ones) with the compression plug below. I was changing the stem so wanted to also change the compression plug. The issue I had with this was the inside of the steerer tube seems a literally more slippery so trying to tighten the plug it just kept spinning against the walls. I tried cleaning the inside surface area with alcohol. That maybe have helped a little. I got it installed but sort of had to angle the wrench a bit to get it to and tighten super slowly to prevent slipping.
It’s seems okay now. No play on the headset although I haven’t not ridden it yet. I’m just trying to sort out if I need to remove it again how to make the process easier.
Should I lightly sand the inside of the steerer tube?
I’ve used this plug on other bikes with no issues.
